93 DTS Tune-Up Question
Results 1 to 6 of 6
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 93 DTS Tune-Up Question in Past Cadillac Vehicle Discussion; I am new to the forum and own a 93 Deville Touring Sedan with a 4.9 ltr. V8. The car ...
    JKLNHDE is offline Cadillac Owners Member
    Apr 2003
    3
    I am new to the forum and own a 93 Deville Touring Sedan with a 4.9 ltr. V8. The car has 70k miles and needs a tune-up. My question's are:
    1-Are any special tools needed to change the spark plugs in this car? Any advice is appreciated should the procedure deviate from normal. I am concerned about changing the 4 plugs against the firewall. Dealer wants $200 to change these-what a rip.
    2-Fuel injector cleaning. What's the best stuff to use? Dealer says that during "thier" tune-up procedure, they add an additve to the tank (2-3 cans of something). IS the GM additive different than an off the shelf injector cleaner available at a regular parts store?
    3-Ignition. I am unfamiliar with the ignition on this car. During a tune up procedure, do you recommend any parts be replaced on the ignition system?
    Thanks for your help and advice regarding anything else I should consider looking at while I've got this thing apart. I am the new second owner and I have no idea what's been done/has not been done to this car.
    Katshot's Avatar
    Katshot is offline Cadillac Owners Master
    Jan 2003
    Newtown, PA
    58
    6,472
    1. No special tools req'd.
    2. A product called "Run-Right" is very good. The stuff you put in the gas tank is mainly "preventive" in nature, not much good for actually cleaning dirty injectors.
    3. Tune-up should involve ALL ignition secondary components as follows:
    Distributor cap
    Rotor
    Plugs
    wires
    Obviously, some cars are DIS so therefore omit the cap/rotor.
    Ralph's Avatar
    Ralph is offline Cadillac Owners 10000+ Posts
    Automobile(s): Cadillac
    Mar 2003
    Saskatchewan, Canada
    16,105
    I would also do the fuel filter and pcv valve. As for the sparkplug wires, I thought they lasted past 100,000 miles?
    Katshot's Avatar
    Jan 2003
    Newtown, PA
    58
    6,472
    He specifically asked about the ignition system. That's why I limited my comments to that system. There ARE other parts that should be done at that time though.
    Qristofer is offline Cadillac Owners Member
    Apr 2003
    12
    I have been trying to change the spark plugs on my deville and trying to reach the rear 4 plugs is a feat in itself. I have all but given up on it. Also changing the cap and rotor is close to impossible because its all incased in a box like unit. I just gave up on it. I want to hear from someone that has changed the plugs on a 4.9L and what kinda tools are best to use.
    Katshot's Avatar
    Jan 2003
    Newtown, PA
    58
    6,472
    I always just used a stubby 3/8ths swivel-head ratchet and a swivel plug socket w/1" extension as I recall. Probably a full-size plug ratchet to break it loose though.
  9. Remove Advertisements
