  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: 2000 deville suspension
Old 05-27-07, 02:01 AM
Danny32687's Avatar
Cadillac(s): Cadillac Deville 2000
View Danny32687's Photo Album
Casino Cash: $250
Exclamation 2000 deville suspension
so i've seen threads about my similar problem but they were for older models. i have 2000 deville and my rear end is sticking up about 4 inches then normal and it has made it very stiff to drive. the compressor works cause i always hear it turn on when i get out of my car, but for some reason it wont level off. what can cause this problem? and how do i fix it myself? please help!
  #2 (permalink)
Old 05-27-07, 08:06 AM
Cadillac(s): '98 STS
View JimD's Photo Album
Casino Cash: $20483
Re: 2000 deville suspension
We always need trouble codes ("DTC") to point you in the proper direction. Read post #2 at this location to display your codes http://www.cadillacforums.com/forums...s-warning.html
You are interested in C prefix codes for this situation. And it sounds like your Electronic Level Control exhaust valve might be causing the problem.
But we need the codes first.
  #3 (permalink)
Old 05-27-07, 01:27 PM
Danny32687's Avatar
Casino Cash: $250
i already checked the codes. there are no current codes, everything is all history
  #4 (permalink)
Old 05-27-07, 01:52 PM
Cadillac(s): 99 Z-rated STS, 90 Coupe Deville (sold)
View chubbyranger's Photo Album
Casino Cash: $2635
History codes can still lead you to the problem since some do not remain current once the ignition is cycled. Could be that the level sensor switch is not shutting the compressor off, possibly a bad switch or dirty contacts. In that case the compressor could run until it times out. Does the back end cycle up and down or does it always sit ass high?
  #5 (permalink)
Old 05-27-07, 02:48 PM
Danny32687's Avatar
Casino Cash: $250
it's always up high.
  #6 (permalink)
Old 05-27-07, 03:20 PM
Casino Cash: $20483
Dump the the air pressure by removing the air line attached to either one of the shock bags.
Then let the compressor do its test cycle at KEY ON. If the back end stays up, you will eventually get a code.
  #7 (permalink)
Old 05-27-07, 07:51 PM
View Ranger's Photo Album
Casino Cash: $27171
Sounds like a bad exhaust solenoid valve. I'd expect one of the following DTC's.
C1737 - Exhaust Solenoid Valve Short to Battery
C1738 - Exhaust Solenoid Valve Short to GND
  #8 (permalink)
Old 05-28-07, 09:58 PM
Danny32687's Avatar
Casino Cash: $250
so i checked the codes. i have two current codes AMP U1000, and IPM B0429. but i also have a crap load of codes that say history.
amp b1004
amp b1327
ipc b1004
ipc b1327
i[c b1438
ipc u1192
ipm b1004
pcm p1106
pcm p1599
pcm u1192
rcc u1000
idk if any of those matter. also shouldnt i get a check engine light for those 2 codes that are current?
  #9 (permalink)
Old 05-28-07, 10:15 PM
Danny32687's Avatar
Casino Cash: $250
i did dump all the air pressure but it went back up. i drove around for about half hour but still no new code beside the ones i just posted. and i got those codes before i dumped all the air
  #10 (permalink)
Old 05-28-07, 10:21 PM
Casino Cash: $27171
Check the actuator/sensor under the rear end. The linkage arm may be bent, broken, disengaged.
  #11 (permalink)
Old 05-28-07, 10:25 PM
Danny32687's Avatar
Casino Cash: $250
is it under the driver side?
  #12 (permalink)
Old 05-28-07, 11:02 PM
Casino Cash: $27171
I think it is on the passengers side.
Tags: , , , , , , , ,
2000, deville, suspension
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
