Results 1 to 3 of 3
Thread: Codes F32, F47??
    inmycadillac's Avatar
    inmycadillac is offline Cadillac Owners Enthusiast
    Automobile(s): 06 DTS Luxury II-?, 98 Eldorado-Crimson Pearl
    Jan 2004
    North Dakota
    40
    511
    Question Codes F32, F47??
    anyone know for sure what they mean? i did a search and found F32-loss of communication between ECM and BCM??!! F47-low refrigerant or bad compressor or no refrigerant?? is 47 what causes the "service air cond" light to come on and switch from auto to econ?? any ideas/answers would be appreciated.
    Mar 2004
    EVERETT MASS
    50
    82
    Re: Codes F32, F47??
    im not sure what it means ecm-emission control module and bcm=bodycontrolmodule but woud say the 47 code is due toe a/c compressor is no good is why light is coming on. good luck!
    Mar 2004
    34
    uhm, you're incorrect. please don't post bad info it's not helpful to people who are already concerned with a broken car.
    you probably have a bad BCM - body control module and your ECM, which is your ENGINE control module
    the a/c code means you're low in r12. get it converted to r134a (if not already done) and have it filled. your compressor is probably fine.
  • You may not post replies
