94 sedan deville help please
Results 1 to 10 of 10
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, 94 sedan deville help please in Past Cadillac Vehicle Discussion; My sedan overheated on me once about 2 weeks ago there was anti freeze sitting on my engine block.So I ...
    94CADDYDADDY is offline Cadillac Owners Member
    Dec 2003
    My sedan overheated on me once about 2 weeks ago there was anti freeze sitting on my engine block.So I looked and found I had a hose coming from the engine to the heater control valve that had deteriorated and had a whole in it.So I replaced the hose and changed my coolant.Drove for about 30 minutes and had no problems.I drove up a hill and then the reservoir tank started bubbling and overflowed.Doesnt appear to be the thermostat I would like to know how do I check for a defective water pump?Because I still smell a sweaty odor when driving but hasnt overheated.
    Cadillac-Junkie's Avatar
    Cadillac-Junkie is offline Cadillac Owners Member
    Mar 2004
    EVERETT MASS
    50
    82
    Re: 94 sedan deville help please
    have u tried to pressure test it yet??
    Dec 2003
    dont know how to pressure test.please advise?
    Mar 2004
    EVERETT MASS
    50
    82
    u need a pressure tester. It screws onto ur radiator cap and u pump it up like a air pump and it puts stress on ur system. any local garage can do it for ya for nuttin or cheap money. good luck ,Sal
    Imprl59 is offline Cadillac Owners Fanatic
    Jan 2004
    300
    I hate to even think it but it sounds like you may have blown a head gasket. As another poster has already said you can get a leak down test done. I would also reccomend you take it to a radiator shop and have them test to see if you are getting exhaust gasses in the radiator. Unfortunatley most all modern engines have zero tolerance for overheating. That temp light might as well say "Too Late Baby".
    I hope it turns out to be something simple like a bad radiator cap. Please let us know what you find out.
    Steve B.
    HippieD9 is offline Cadillac Owners Fanatic
    Nov 2003
    Suburb of Chicago
    34
    176
    94, is that the 4.9 or the N*? I'd try a new thermostat and radiator cap. If it's the 4.9, try running a 180 instead of the stock 195. Not to scare you, but I had a similar problem with a 4.1 The coolent passages got blocked and then there's nothing you can do. The motor was trashed for a rebuilt 4.9.
    Peace,
    D.
    RBraczyk's Avatar
    RBraczyk is offline Cadillac Owners Connoisseur
    Jan 2004
    Amherst, NH
    29
    4,178
    Quote Originally Posted by Imprl59
    Steve B.
    I blew my secondary belt last november and I drove 30 miles to my service station in which the 4.9 overheated, but caused no damage. Damn loose pulley.
    Stoneage_Caddy's Avatar
    Stoneage_Caddy is offline Cadillac Owners 10000+ Posts
    Automobile(s): 01 frontier , 89 Shelby CSX vnt
    May 2003
    Undisclosed location in FL
    14,607
    "I blew my secondary belt last november "
    you have 2 belts ?
    RBraczyk's Avatar
    Jan 2004
    Amherst, NH
    29
    4,178
    The fan belt is linked to all the "secondary" things, ie power steering pump, ventillation, ac compressor, ride control compressor, all those goodies. It was hell driving home those 30 miles without ride control or power steering
    I had to put most of my weight 220 lbs to turn the wheel, it sucked big time.
    May 2003
    14,607
    what a weird car , my 94 only has one belt that runs everything , i dont have a ride controll pump .....just powersteering , alternator, waterpump ,ac compressor and a couple idlers (7 pulleys alltogether )
    yours is a sedan deville right ? i dont see a northstar there so it must be ...
  13. Remove Advertisements
