  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: I think my mechanic screwed up
Old 05-09-07, 05:07 PM
97DevilleBeige's Avatar
Cadillac(s): 97 Deville
View 97DevilleBeige's Photo Album
Casino Cash: $1615
Hi guys. I went in for an oil change to my regular mechanic, and I asked him to refill the refridgerant because the message said to put some in. It locked out the a/c when the message came on, which I understand is normal. When he put the refridgerant in, the compressor started making all sorts of weird noises besides the normal rattle. He told me to shut the car off. Then he let some of the r134 out, and told me to start it up again. Same thing, it was very violent. The third time, the car shut off by itself, everything, including the engine. He then said "you need a new compressor." He disconnected it, and told me not to use the a/c. What do you guys think? Is it something he could have screwed up, or was filling it up the straw that broke the camels back? Thanks in advance.
  #2 (permalink)
Old 05-09-07, 07:05 PM
Cadillac(s): 1996 Deville (sold), 2000 Mustang GT
View misfit6794's Photo Album
Casino Cash: $9389
Re: I think my mechanic screwed up
I doubt it was anything he did. The a/c compressor went on my 96, made some really really bad sounds too. Eventually it will seize up and in turn melt your serpentine belt. I got away with driving with it bad for awhile tho, and I traded it in that way. The compressor is anywhere between 400-600 dollars, and the labor? big $$$$, its on the bottom of the engine.
  #3 (permalink)
Old 05-09-07, 09:07 PM
Cadillac(s): Cadillac
View skankyfrankie's Photo Album
Casino Cash: $510
If the clutch went out they make a bad noise and are not all that expensive to replace. If the compressor went the whole system will have to be backflushed, evap filter will have to be changed. When they go out like this they come apart and send debri down the lines. Since they pretty much cycle on and off winter and summer they were out faster than the old days.
  #4 (permalink)
Old 05-09-07, 09:24 PM
Cadillac(s): Sedan de Ville, CTS
View z06bigbird's Photo Album
Casino Cash: $5444
Used to be able to change out the parts yourself, evacuate the system, and let the a/c guy complete the job. Not anymore. Big $$ now.
  #5 (permalink)
Old 05-09-07, 10:54 PM
View Ranger's Photo Album
Casino Cash: $27171
Sounds like the camel and the straw to me. I don't think he caused it.
  #6 (permalink)
Old 05-16-07, 02:56 PM
Casino Cash: $1615
Ok, well here's the story... my mechanic doesn't do big jobs like this, so he sent my car over to a guy who he farms bigger jobs out to, and he estimated about $1000 for the job. I called the Cadillac dealer I work with occaisionally, and he quoted me the same price. I'm probably going to have it done by him.
NOW the question is... what do I ask him to do? What should I make sure that the dealer does? Just the compressor? what about changing an evaporator, condensor, and all sorts of other thingamabobs that go along with the job? There is some sort of leak in the system somewhere, because I've been recharging the R134A about once a season per the message on the dashbaord that pops up. How do I know if this will go away once the compressor is changed? Also, is there anything else he should do while he's got the car apart in that area?
  #7 (permalink)
Old 05-16-07, 03:28 PM
Casino Cash: $9389
I am sure if they replace the compressor they will inspect the rest of the a/c to make sure its working properly. 1000 dollars seems to be the number when it comes to replacing those.
  #8 (permalink)
Old 05-16-07, 09:26 PM
Casino Cash: $27171
Most A/C leaks come from the compressor shaft seal. Is the front of the clutch plate wet? If the compressor has started to disintegrate, debris will be carried through the system. The orifice tube will catch most of it and will tell the tale when it is inspected. If that is the case, then the accumulator and the condenser need to be replaced as well and all the lines must be flushed, but I am sure the dealer mechanics would know that.
Tags:
mechanic, screwed
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
