Cadillac DeVille 1985 to 2005 including: 1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille, 1985-1992 Fleetwood and 1993 Sixty Special. | Cadillac Forums: Check Gas Cap Warning 02 Dts
05-05-07, 05:16 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Check Gas Cap Warning 02 Dts When I First Got My Car Last Year This Warning Came On I ReplAced My Gas Cap And Now About 5 Months Later The Warning Is On My Dash Again I Know There Is Know Way This Cap Went Bad That Fast And The Cap Is On Tight What Do You Think It Could Be |
05-05-07, 05:38 PM
| | my name is Tiffany Cadillac(s): 05 CTS-V | | Join Date: Mar 2003 Location: San 'tone, TX | | | Re: Check Gas Cap Warning 02 Dts #1. caps lock OFF please
#2. you posted this in 2006+ DTS forum...please post in the proper forum for your vehicle. |
05-05-07, 06:12 PM
| | Cadillac Owners Member Cadillac(s): White Diamond '03 DHS | | Join Date: Jun 2004 Location: Woodstock Ill. Age: 61 | | | Re: Check Gas Cap Warning 02 Dts Always start by pulling the codes. Might be a problem with the EVAP system. |
05-06-07, 08:25 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Check Gas Cap Warning 02 Dts sorry yesterday was my first day on here still trying to get the hang of it.
and i also went and got the codes and it did say the evap system had a leak and i know its not the gas cap cause i just replaced it this year so i geuss i need to take it to the dealer how much do you think this might cost to get fixed |
05-06-07, 09:05 AM
| | Cadillac Owners Connoisseur Cadillac(s): '98 STS | | Join Date: Sep 2003 Location: Atlanta area | | | Re: Check Gas Cap Warning 02 Dts Tell us what codes were displayed. |
05-06-07, 09:09 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Check Gas Cap Warning 02 Dts ok im gonna have to go back to auto zone and get them to write it down for me he just said it was a leak in my evap system |
05-06-07, 10:05 AM
| | Cadillac Owners Connoisseur Cadillac(s): '98 STS | | Join Date: Sep 2003 Location: Atlanta area | | | Re: Check Gas Cap Warning 02 Dts Autozone would be one way to display the codes.
Or you could read them yourself from the DIC. See post #2 here http://www.cadillacforums.com/forums...s-warning.html |
05-06-07, 11:08 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Check Gas Cap Warning 02 Dts ok thanks i pulled them myself
and i got alot of history codes but my current codes are
ipm b0429
pcm p0440
pcm p0442 |
05-06-07, 11:13 AM
|  | Cadillac Owners Connoisseur Cadillac(s): 01 Eldo ETC, 02 Deville | | Join Date: May 2004 Location: Salem, NJ Age: 56 | | | Re: Check Gas Cap Warning 02 Dts I think the P0440 is the Evap Sensor up on the engine. Had the same prob with my '99 Deville. It was a relatively cheap fix at the dealer, if I remember.
"For a successful technology, reality must take precedence over public relations, for Nature cannot be fooled." - Richard P. Feynman  |
05-06-07, 11:18 AM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Check Gas Cap Warning 02 Dts ok thanks alot |
05-06-07, 12:23 PM
| | Cadillac Owners Connoisseur Cadillac(s): '98 STS | | Join Date: Sep 2003 Location: Atlanta area | | | Re: Check Gas Cap Warning 02 Dts P0440 and P0442 can both be caused by leaks. Double check all the vacuum hoses and connections in the evap. plumbing. |
05-06-07, 12:40 PM
| | Cadillac Owners Member Cadillac(s): Cadillac | | | | | Re: Check Gas Cap Warning 02 Dts ok thanks i dont know to much about working on cars so i dont even know which hoses to check  so im gonna have to take it to a shop |
05-07-07, 09:48 AM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 70 | | | Re: Check Gas Cap Warning 02 Dts There is/was a factory recall for Seville/Deville in the '01-'03 series for a faulty fuel tank pressure sensor. This will trigger the "fuel cap" code. Check your VIN with any dealer's GM service history computer files to see if the recall was done. There MAY be a GM "campaign" sticker on the water pump belt guard....recall #03038, I think..... |
05-07-07, 09:57 AM
|  | Cold Soaked Cadillac(s): 2006 STS AWD, '95 Ford Ranger | | Join Date: Jul 2004 Location: Fairbanks, Ak Age: 70 | | | Re: Check Gas Cap Warning 02 Dts Buicks had the same problem.
__________________ Don't mess with Binky Bear! | | Cadillac Discussion Tools | | |
Censor is ON | | | |
