thanks for the responses, guys.
Originally Posted by krimson_cardnal Exactly what do you have in mind when you say tune up? Nothing you couldn't handle... |
hm.. chicken i guess. have been shocked by my own ineptitude lately. i've changed lightbulbs around the car and the window motor, air filter. just the simple no-risk stuff not related to the actual running of the car. read some on changing plugs and the talk of cross-threading or breaking plugs and dropping bits into the cylinders made me think i should avoid it. i'd have to do it outdoors in some parking lot also. it's really dusty around here. but.. now it sounds tempting..
the dealers say they'd change plugs, wires, check the timing, check the throttle plate (extra charge to clean), oil change, fuel filter i think? i checked with another dealer who wanted $800.
ah.. if i took it to the dealer i think they'd be able to spot any other problems that needed fixing.. while trusting them to be honest on that.. so if it is something else like a vacuum leak or something else i wouldn't know about.. or if there were some other problem i wouldn't know to look for.
Is this the right part # on the wires?
ACDELCO Part # 748J {#12192049}
WIRE KIT,SPLG
i'd need a torque wrench - never used one.
a plug socket for the wrench?
do new plugs need to have the gap adjusted?
if i end up diy-ing - you think this can wait a few days more for the parts to arrive?
