  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: A/C compressor clutch
Old 04-24-07, 08:23 PM
Cadillac(s): 1994 Concours
View k63d400's Photo Album
Casino Cash: $250
So the bearings in my old cluch gave out. I got the right tools, and a new clutch finally. I bypassed the system for the past 16 months with a shorter belt.
So i have the new clutch on but the clutch won't engage. Checked the relays and fuses, if i put a jumper in the relay it comes on but isn't cold, only ran it for 40 sec just in case some thing else is wrong.
I gave it a quick shot of R134a, now it cycles on and off, but wont stay on.
Is there something i missed? The clearance between the pully and hub is .030"
When i jump the relay is kicks on and holds.
I plan on taking it to a a/c place and seeing if it needs to be charged.
  #2 (permalink)
Old 04-24-07, 09:34 PM
View Ranger's Photo Album
Casino Cash: $27171
Re: A/C compressor clutch
If the system is low on refrigerant it will disable the compressor to prevent damage. It will also set a DTC which must be cleared before recharging to enable the compressor. When it is running properly, the compressor will cycle on & off. It will rarely run continuously. Perhaps in 100 degree heat.
  #3 (permalink)
Old 04-24-07, 11:35 PM
Casino Cash: $250
no codes have been set and no low 'refrigerant message'.
the compressor will kick on for about 5 seconds then turn off, 30 seconds later it'll kick on again & turn right off.
  #4 (permalink)
Old 04-25-07, 01:09 AM
Casino Cash: $27171
What is the outside temperature? Are the vents blowing cold air?
  #5 (permalink)
Old 04-25-07, 04:11 PM
Casino Cash: $250
75-80F.. Vents aren't blowing cold just ambient air.
The static pressure is about 35psi
  #6 (permalink)
Old 04-25-07, 10:55 PM
Casino Cash: $27171
Static pressure means nothing. What are your high and low side pressures when the compressor is running? Have you checked the DTC's?
  #7 (permalink)
Old 04-26-07, 11:22 AM
Casino Cash: $250
Got it fixed, was about 1 1/2 cans low.. When running it was just below the the shut off pressure but didn't set off any DTCs. Blowing cold now. The high-side valve was leaking a bit but then a bit of oil came through and it closed up. About 2-3 mL of oil came out, should i worry about it and add some oil?
I have ~170psi on the high and about 25 on the low @ 1500 RPMs... It is 68F (med humidity) here today.
  #8 (permalink)
Old 04-26-07, 04:19 PM
Casino Cash: $27171
Without looking at a chart, those pressures sound about right, but Freon moleculles are very, very small and if you have a leak, it will leak down again rather quickly.
  #9 (permalink)
Old 04-27-07, 12:07 AM
dkozloski's Avatar
Cold Soaked
Cadillac(s): 2006 STS AWD, '95 Ford Ranger
View dkozloski's Photo Album
Casino Cash: $18067
A common place for leaks is the compressor seal, especially if it hasn't turned for a long time. Fords exercise the a/c compressor constantly, even in sub zero weather for this reason. Yours might heal itself up.
Don't mess with Binky Bear!
Tags: ,
a or c, clutch, compressor
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
