  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: 'Change Trans Fluid'
Old 04-20-07, 11:19 AM
Cadillac(s): 1994 Concours
View k63d400's Photo Album
Casino Cash: $250
Post 'Change Trans Fluid'
I received the 'change trans fluid' message the other day.
My brother is a mechanic and owes me a favor so he is going to change the fluid for me, just had one question.
He is going to pull the pan and replace the filters and all, should he just do the 5 qts in the pan or pull the plug from inside also and do the 11qts or so.
I ask because my car had 156k miles and to be honest i don't know if the previous owner had a trans fluid changed and I've heard horror stories about changing the fluid. Thus far i've had no problems with the transmission.
Also someone recommended Dex VI instead of III, any thoughts?
  #2 (permalink)
Old 04-20-07, 12:36 PM
View Ranger's Photo Album
Casino Cash: $27171
Re: 'Change Trans Fluid'
Drop the pan AND pull the drain plug under the side cover inside. No filters to replace. The two screens are reusable. Just clean them if there is anything in them. Mine were clean at 100K ('97 Deville). Dexron VI (or whatever the latest is) supersedes Dexron III so use what ever is available now.
The CHANGE TRANS FLUID message is not mileage related like the OLM. It usually only comes on if the trans has been overheated to the best of my knowledge.
  #3 (permalink)
Old 04-20-07, 02:06 PM
codewize's Avatar
Cadillac Owners Master
Cadillac(s): 1989 STS / 2001 DTS / 2002 DTS
View codewize's Photo Album
Casino Cash: $16170
I went crazy during my rebuild and filled with Amsoil fluid. I figured if I was going to do it at all that was the time.
Ownership:
89 STS (1 of 1893) - FOR SALE
02 DTS
01 DTS:
Custom installed Volant CAI
Custom PCM
Body color engine components
Cruiser Alloy wheels
EBC brakes
Eibach springs
Corsa exhaust
Sportwing Spoiler
Semi-custom interior
Custom quad Hi-Beams
Future Plans: More interior work.
Memberships:
National and regional Cadillac & LaSalle Club
Proud Volunteer - Northstar Tuning Project
  #4 (permalink)
Old 04-20-07, 04:17 PM
JCM1's Avatar
Cadillac(s): 1994 Deville Concours, 1997 Seville SLS, 1981 Eldorado
View JCM1's Photo Album
Casino Cash: $885
I agree with Ranger in the draining of both the pan and the valve body. I did this job this past fall on my DeVille. I did however, replace the filters. They were not bad but, might as well. You can get a filter and gasket kit at Autozone for around $25. I did not replace the gasket as the kit gave me a cork one and the dealer put a rubber one on a few years ago when the trans was serviced. Don't forget to wipe off the magnet on the pan. I used Mobil One synthetic to replace the fluid.
  #5 (permalink)
Old 04-20-07, 04:23 PM
Cadillac(s): 92 eldorado, 97 S.T.S..
View creeker's Photo Album
Casino Cash: $17465
Hello Ranger,I changed filter and fluid in my 80 cdv ,6.0 litre last year ,I didn't know there was a valve body drain, would my car have this valve body drain, tnx Ken
  #6 (permalink)
Old 04-20-07, 08:52 PM
Casino Cash: $27171
The drain is not for the valve body, but for the side cover. Not sure what trans you have. The 4T80E is a dry sump, so the fluid is stored in the side cover, where you add the fluid. There is a drain plug below it, inside the pan that must be removed to drain the side cover.
  #7 (permalink)
Old 04-20-07, 08:57 PM
John Wicz's Avatar
Cadillac(s): White Diamond '03 DTS
View John Wicz's Photo Album
Casino Cash: $1975
The CHANGE TRANS FLUID message is not mileage related like the OLM. It usually only comes on if the trans has been overheated to the best of my knowledge.[/quote]
Mine is at 99%, are you saying that it never decreases.
  #8 (permalink)
Old 04-20-07, 09:13 PM
Casino Cash: $27171
Yes. unless you overheat it.
  #9 (permalink)
Old 04-20-07, 09:59 PM
Casino Cash: $17465
Thank you
Tags: , , ,
change, fluid, trans
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
