  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: Quick MAP sensor question
Old 04-14-07, 08:46 AM
Cadillac(s): 1994 Concours
View k63d400's Photo Album
Casino Cash: $250
I have a 1994 Concours and a few weeks ago the car began to run badly and put out codes for the map sensor. I replaced it and the car runs 'ok'.
The sensor i have has lettering above the connector (C B A)
The wiring harness says (A B C)
This is a brand new part for the car, i even exchanged it once at the auto parts store and the 2nd one had the same connection.
If the wiring was reversed like that would it be aparent right way? Current I have no PCM codes and it has been 3 weeks.
  #2 (permalink)
Old 06-27-07, 09:06 PM
Cadillac(s): Cadillac
View kurtnukes's Photo Album
Casino Cash: $325
Re: Quick MAP sensor question
I own a '94 Concours also, and just replaced the MAP. The electric terminal end has a locking clip (on the top of the MAP in your picture) which only allows the connection to go on one way. You have it on correctly. Even if the clip is broken off, the telltale trace of where the clip used to be will show that the clip strattles/locks onto the square raised tab of plastic on the MAP sensor itself. My MAP didn't have ABC labeled on it, but the connection did have CBA like yours.
When replacing mine I encountered a problem in that my 4.6L N* has a MAP sensor that should be on a 4.9L! It is a totally different design from a 4.6L (which looks like yours) and the male/female pins were reversed. The dealer and ACDelco Tech line was at a loss for an explanation, as the wiring was original, and not "spliced". It was a GM "one off". I found a correct replacement from Lee Auto Parts after the dealer gave up trying to help me find the correct one.
Tags: , ,
map, question, quick, sensor
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
