  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: How to replace a LF window regulator on a 1994 Deville Concours?
Old 04-10-07, 08:50 PM
Cadillac(s): Cadillac
View kai_zhu's Photo Album
Casino Cash: $250
Any experience on it? Many thanks!!
  #2 (permalink)
Old 04-11-07, 02:24 AM
JCM1's Avatar
Cadillac(s): 1994 Deville Concours, 1997 Seville SLS, 1981 Eldorado
View JCM1's Photo Album
Casino Cash: $885
Re: How to replace a LF window regulator on a 1994 Deville Concours?
I'm not sure about how the regulator works however, I do know how you can get to it. The interior door panel needs to come off; the panel comes off by pushing it up from the bottom. Make sure you remove the window, seat, and mirror control panels first and pop off the clip that holds the plastic corner sail panel by the mirror. Also CARFULLY remove the pastic panel with the power lock controls and unplug the wiring harness. Pop off the two plastic covers on either end of the door-pull handle and remove the screws with philips screw driver. After doing this, CARFULLY lift from the bottom. Once the panel as come off, CARFULLY pull the panel far enough away from the door to pull the two speaker connectors off. Put the panel someplace safe, along with the power controls. In order to get to the power window equipment you need to pull back the black rubber sound absorber panel. It is stuck on with a black, gummy, tar like substance. Again, be careful with this as well.
  #3 (permalink)
Old 04-12-07, 02:02 PM
Cadillac(s): Sedan de Ville, CTS
View z06bigbird's Photo Album
Casino Cash: $5444
If you do a search on here, you will likely find 1000 similar posts.
Also, the older cars used to be real good about chopping your fingers off. I don't know if more recent models are as quirky.
Have you tried pounding on door to make sure you really have a problem?
Ed
  #4 (permalink)
Old 05-03-07, 11:16 PM
View curt brown's Photo Album
Casino Cash: $275
have repaired/replaced left front power window motor if you need help in that area.
  #5 (permalink)
Old 09-17-07, 02:21 PM
View tomc65's Photo Album
Casino Cash: $2917
I can sure use some help in installing new motor in front passenger window in 94 deville. thanks in advance
  #6 (permalink)
Old 09-19-07, 09:12 PM
View Tuco's Photo Album
Casino Cash: $260
I just did this last spring. It was very easy. Here is a summary from factory service manual:
1. remove switch plates by using a feeler gauge (or small screw driver) to dissengage the clips to the rear of the switch panels. Push the blade into and under the switch plate about 3/4 inch to dissegage. Then pull out the switch plates and disconnect wires.
2. Remove the plastic rear view mirror cover. It kind of pops off.
3. Remove the door panel by pulling in and up. There are several plastic hooks that hold it in place.
4. Remove water deflector.
5. Remove and replace window regulator (motor).
The hardest part is getting the switch plates off without scratching up the arm rest. A thick feeler gauge worked great for this.
  #7 (permalink)
Old 09-21-07, 01:47 PM
Casino Cash: $2917
Thanks for the instructions. ANY PICTURES??? Or LINK ???
Tags: , ,
1994, concours, deville, regulator, replace, window
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
