Help !!!! VSS or something else My 91 Coupe Deville shifts erratically at lower speeds, below 45mph, and the speedometer goes nuts as well. The VSS was replaced three years ago but did not fix the problem, so the vehicle was parked.
When I first got the car and started driving it there was no problem with the shifting, speedometer or anything like that. Three weeks later it's beginning to act up on a consistent basis. I bought a new VSS to install but am concerned about throwing away $47.00 for nothing. If it isn't the VSS, what could cause this?
It seems to be related to throttle position, as when traveling under 45 and I gently apply throttle the speedometer goes to a zero or 15mph reading then the trans will start shifting up and down erratically.
Help!!!! Does anyone have any good input on this? |
