  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: Rough idle when hot
Old 03-26-07, 01:20 PM
Cadillac(s): 1994 Concours
View k63d400's Photo Album
Casino Cash: $250
Rough idle when hot
I have a 1994 Cadillac Concours. 155,000 Miles
Had a problem the other day that i could not get the car to start, when I finally did the engine ran very rought and it was surging.
After a few hours when the engine cooled I was able to drive it home(10-15min) but just as i got home it started to surge again
Today i put the car in the drive way and let it just run. After exactly 20 min the rpm's started going up and down, under the hood i could see the computer changing the throttle, trying to compensate i guess.
The engine became very erractic and I shut it off when i noticed smoke, which was comming from residue buring off the exhaust pipes and catalytic converter which appeared to be very hot. I also checked the Fuel Pressure Regulator, i took the engine cover off and turned the ignition to ON but didn't start. No fuel came out, I even put a vacuum pump on it and it held a small vacuum for 10 min and no fuel was present. There does appear to be a minor amount of oil coating everything under the engine cover, does that mean anything?
The spark plugs and wires are new, as is the MAP sensor which went bad 2 months ago. 2 weeks back i got a code for a rich fuel system (P080) but that went away when i reprogrammed the PCM with the procedure I read some similar posts on here.
Also I have no computer codes, when it first gave me a problem i had P032, it became a history, I cleared it and it has not returned.
  #2 (permalink)
Old 03-26-07, 03:38 PM
Casino Cash: $250
Re: Rough idle when hot
Waited a few hours, cleared the PCM codes and tried restarting the car. Only ran erraticly for a few seconds then stalled.
Spit out the following codes:
P032 Map sensor open
P031 Map sensor shorted
P071 Intermittent Map signal
Should i assume the new sensor is bad or could it be a PCM problem?
  #3 (permalink)
Old 03-26-07, 06:57 PM
revdowrong's Avatar
Cadillac(s): 91 sedan deville
View revdowrong's Photo Album
Casino Cash: $5833
Well if your part has warranty just take it back for another one and see if the problem comes back.
  #4 (permalink)
Old 03-26-07, 10:05 PM
View Ranger's Photo Album
Casino Cash: $27171
A bad MAP sensor may be causing a rich condition, thus hot pipes.
  #5 (permalink)
Old 03-29-07, 07:56 PM
Casino Cash: $250
replaced the map and the car is running fine...
One question..
The map sensor for my car has the letters C B A above the pins but my wiring harness ahs the order as A B C. If this is on backwards would it cause a MAP sensor failure even though it operates fine now? Also there are no PCM codes such as shorted, open or intermittent
Tags: , ,
hot, idle, rough
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
