  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: New Speakers For a 2000 Deville, What Do I Need?
Old 03-20-07, 11:01 PM
cadillac_pimpz's Avatar
Cadillac(s): Custom 2005 Cadillac Deville, Pimp Edition
View cadillac_pimpz's Photo Album
Casino Cash: $1503
I have a 2000 Deville, and my back, center speaker is blown. I need to get it replaced, but I need to confirm what kind I need. I went to Cadillac and of course it would cost me like $650 to get it replaced. I went to best buy and talked to the car audio guy, and he said that if they are Bose speakers, then I can't replace the one speaker. I am pretty sure my speakers are not Bose, none of them are marked. So then I went to Fry's electronics, and talked to the installer which said that it is a 10" freeair speaker (without taking a look at my car). So I would just like to confirm that I need a new 10" freeair speaker. Also, im thinking about putting subs and a box in my trunk, but I don't realy know anything about sound systems. So could someone explain them to me? thanks.
  #2 (permalink)
Old 03-20-07, 11:06 PM
Cadillac(s): 1997 Cadillac ETC
View OffThaHorseCEO's Photo Album
Casino Cash: $3020
Re: New Speakers For a 2000 Deville, What Do I Need?
if the radio says bose on it then its bose, if it doesnt say bose on it then they arent. i used a 10" incher but had to make a plate for it cause it wouldnt bolt up right, the hole is bigger than 10 inches if i remember right it was either 10.5 or 11
  #3 (permalink)
Old 03-20-07, 11:17 PM
Casino Cash: $1503
was yours blown too? did everything fit back together ok? I hear you have to take the back seat out and that panel back there to get to the speaker. I have taken the back seat out though, to find the battery.hahahaha it took us forever to find that thing. XD
  #4 (permalink)
Old 03-21-07, 10:19 AM
Casino Cash: $3020
yea i had to pull the backseat away, you in between each set of headrests is a huge metal clip, i GUESS you could slide a tool down there and force it down, but my hands did it pretty well, i just locate the clip, and push down while pullin the seat out. when you do all 3 theres a couple of plastic clips holding the carpeted shelf in, and youll also have to wiggle the seatbelt surround out of the shelf. the sub is also held on by plastic clips 6 of them.
maybe its just the sub i used, others may have had better luck or experience with it but...
anyways i used a wooden spacer and since they are cut square i had to round off two of the edges (i didnt have any tools so i didi it the ghetto way, i looked like a caveman sittin there grinding wood against concrete haha. but it came out smooth hehe)
i didnt have dynamat so i ultimately disconnected it cause it didnt perform to my liking (and it rattled the deck)
  #5 (permalink)
Old 03-21-07, 11:39 AM
Casino Cash: $1503
so you disconected the speaker? How does the sound system sound without it? Also, could a system in the trunk make up for it?
  #6 (permalink)
Old 03-21-07, 12:25 PM
CadillacSTS2003's Avatar
Zeeee-yaaaa
Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC
View CadillacSTS2003's Photo Album
Casino Cash: $12230
yuh a sub system in the trunk can DEF make up for it ahahha
  #7 (permalink)
Old 03-21-07, 03:24 PM
Casino Cash: $3020
agreed, the system definitely makes up for it
i disconnected the blown factory sub cause it made a caca noise but its not that easy to put a aftermarket system in, the wiring (power ground remote) is easy its the signal thats not so easy
  #8 (permalink)
Old 03-21-07, 06:30 PM
Casino Cash: $1503
what signal?
  #9 (permalink)
Old 03-21-07, 06:31 PM
Zeeee-yaaaa
Casino Cash: $12230
what are you talking about
"signal?"
  #10 (permalink)
Old 03-21-07, 11:10 PM
Casino Cash: $1503
this may be a little off topic, but could you tell me how to get a pic of my Caddy in my sig?
  #11 (permalink)
Old 03-21-07, 11:45 PM
Zeeee-yaaaa
Casino Cash: $12230
become a supporting member
only way
  #12 (permalink)
Old 03-21-07, 11:49 PM
Casino Cash: $3020
"signal?"
getting a signal to the subs, getting you can use a LOC but if the sub is blown and uninstalled it makes it harder
  #13 (permalink)
Old 03-22-07, 12:09 AM
Casino Cash: $1503
Or I can be cheap and just paste a pic into every post I make. XD
  #14 (permalink)
Old 03-22-07, 12:11 AM
Casino Cash: $1503
I still don't know what your talking about, but I will talk to someone about it, and see what I can do.
  #15 (permalink)
Old 03-22-07, 02:19 AM
Casino Cash: $3020
if you just hook an amp up to a speaker it just sits there, doing nothin. when you feed it sound (a signal in my words) then it reacts and reproduces that sound which in a subwoofers case would be bass. so if you decide to put an aftermsrket system in, you will have to run a power wire, a ground wire a remote wire and rca cables which will more than likely need to go to a line out converter (LOC). a line out converter takes speaker level (high) signals and turns it into low level signal, its usually a box with places to plug in speaker wires on one side and rca outs on the other side. the issue is, where to get the signal from. nvm, ill just let you run into the problem then explain it to you then
Tags:
2000, deville, speakers
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
