Water pump needs replaced - help!
Page 1 of 2 12 LastLast
Results 1 to 15 of 21
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Water pump needs replaced - help! in Past Cadillac Vehicle Discussion; To All, I have a 1993 Deville with a 4.9 liter engine. My water pump needs replaced and I have ...
    Green Horn is offline Cadillac Owners Member
    Mar 2004
    1
    To All,
    I have a 1993 Deville with a 4.9 liter engine. My water pump needs replaced and I have never replaced one before. Guys I work with say that it's easy to replace - is that true? Can someone walk me though the replacement? I don't have the money to pay a pro - I'm no great mechanic - but I follow directions pretty well. I need replace this water pump tomorrow - by myself - please advise...
    Green Horn
    Stoneage_Caddy's Avatar
    Stoneage_Caddy is offline Cadillac Owners 10000+ Posts
    Automobile(s): 01 frontier , 89 Shelby CSX vnt
    May 2003
    Undisclosed location in FL
    14,607
    Re: Water pump needs replaced - help!
    go to the all data site , for 14.95 you get a subscription to the service and you get proceedures and torque specs to do it , i will be replaceing mine in the next few weeks as ive got a bearing going bad in it and im useing the all data proceedures (doesnt look bad skill wise )
    Paul Nagy is offline Cadillac Owners Member
    Jan 2004
    Clovis, NM, USA
    53
    If it is the same as the '94, you have to remove the belt, of course, and then power steering pump pulley to get to the water pump. Otherwise it is not that difficult. Make sure to put a large pan underneath to catch all the draining coolant. I remove the battery because I like the extra space to work in, and I also used sealant along with the new gasket to be sure that the pump did not leak. Chiltons has the torque specs, too, although fitting a torque wrench on all those bolts was not possible for me, so I just made an educated guess.Good luck.
    MrSmith's Avatar
    MrSmith is offline Cadillac Owners Enthusiast
    Mar 2004
    800
    So we do have a timing belt right? Sorry Im a new 91'Devilion and dont know anything about Cadillac.
    In order to remove our water pumps we need to remove the timing belts , is this correct?
    May 2003
    14,607
    nope no timing belt just a single serpentine belt that runs the accerorys like the waterpump , ac comp ,power steer pump and alternator , we got a chain for timing , no worrys there
    MrSmith's Avatar
    Mar 2004
    800
    Sounds like good news to me
    May 2003
    14,607
    just got done replaceing mine , wasnt a bad job outside my bad back , makes leaning over fenders a nasty experence
    MrSmith's Avatar
    Mar 2004
    800
    The caddy my pops is suppose to be giving me may need some work. I asked him today how many miles are on it. {he's in another state} He said 155,000. Not to bad but then he said He had it for about 5 years and nothing has ever gone wrong with it and all he has ever done was change the oil. So Im thinking I need to change plugs, wires etc....:rolleyes2 So tell me. what tune up parts do these cars require??
    May 2003
    14,607
    i dont know about changeing the plugs just yet , thats a pretty difficult job getting to the rear bank of plugs. if you have some time and patince then you might give it a try
    i sugest building your confidence first by changeing the fuel filter
    but first and foremost get a reapir manual and read the proceedures and get a good idea on what your gonna do and see if your ok with it
    MrSmith's Avatar
    Mar 2004
    800
    Thanks, Ill look for a chiltons
    CaddyShaq is offline Cadillac Owners Member
    Mar 2004
    Trenton, NJ
    39
    45
    Quote Originally Posted by Stoneage_Caddy
    Difficult is an understatement. I bought the plugs and looked back there, getting ready to do the job and just said forget it. I looks like a lot of work. When you do get your repair manual, please enlighten us on the proper procedure for changing the plugs on the rear banks.
    Jan 2004
    Clovis, NM, USA
    53
    Plugs can be replaced; it's just a major hassle, and requires a lot of time. I found a flexible adaptor for a my ratchet helpful.Don't be afraid to remove hoses and pieces that are in the way.
    RBraczyk's Avatar
    RBraczyk is offline Cadillac Owners Connoisseur
    Jan 2004
    Amherst, NH
    29
    4,178
    Try to get one of those Jeg's tool apron things so you can store your tools in it and you can lean on your car without destroying the finish.
  16. #14
    HippieD9 is offline Cadillac Owners Fanatic
    Nov 2003
    Suburb of Chicago
    34
    176
    Best way to do the plugs is from under the car with a long extension and a swivel or two, lot easier than the top. 5min job if you have a lift.
    Peace,
    D.
  17. #15
    Mar 2004
    Trenton, NJ
    39
    45
    Quote Originally Posted by HippieD9
    Peace,
    D.
    Please elaborate. I am interested to know how I would get to the plugs from underneath the car.
  18. Remove Advertisements
