Water pump needs replaced - help! - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum Discussion, Water pump needs replaced - help! in Past Cadillac Vehicle Discussion; If you have it up on a lift the plugs are easily accessable from the rear of the engine, by ...
  1. #16
    HippieD9 is offline Cadillac Owners Fanatic
    Nov 2003
    Suburb of Chicago
    34
    176
    Re: Water pump needs replaced - help!
    If you have it up on a lift the plugs are easily accessable from the rear of the engine, by where the downpipe from the manifolds comes down to the cat. Look up there, you'll see 'em!
    D.
  2. #17
    CaddyShaq is offline Cadillac Owners Member
    Mar 2004
    Trenton, NJ
    39
    45
    Quote Originally Posted by HippieD9
    D.
    How about with a jack and stands? Is it still as easy?
  3. #18
    Mar 2004
    Trenton, NJ
    39
    45
    Or ramps? How about that? I am gonna definitely do it this weekend one way or the other. The weather is supposed to be beautiful.
  5. #19
    josmoe1100cc's Avatar
    josmoe1100cc is offline Cadillac Owners Member
    Nov 2004
    25
    I've changed the plugs in my '90 deville and my parents '94 deville. To get the back plugs I just put my knees on the metal bar in front of the radiator and leaned over the back of the engine with a small extension, swivle, and my spark plug socket. It's not a fun job, but it can be done. The biggest problem I had was the front plug 2nd from the left. The a/c hoses and a support bar were in the way. I broke one plug trying to get it in, so might be a good idea to have an extra one or two on hand.
  6. #20
    MrSmith's Avatar
    MrSmith is offline Cadillac Owners Enthusiast
    Mar 2004
    800
    Quote Originally Posted by CaddyShaq
    When you do get your repair manual, please enlighten us on the proper procedure for changing the plugs on the rear banks.
    It doesnt say how or even give a picture . Just tells you were they are..
  7. #21
    Insomniac's Avatar
    Insomniac is offline Cadillac Owners Fanatic
    Feb 2004
    wichita, kansas
    29
    110
    i changed the plugs on my HT4100. it took me the good part of a day, it was very hard work and all my friend with their little hondas made fun of me because it took so long . the hardest one for me was the front far left one because the a/c pully was in the way. i did it all from the top and my back hurt a little afterwords. good luck!
  8. Remove Advertisements
