  Follow CadillacOwners on Twitter
Go Back   Cadillac Owners Group > Past Cadillac Vehicle Discussion > Cadillac DeVille 1985 to 2005 including:
1985-1992 Fleetwood, 1993 Sixty Special, All FWD Forum
Forum for discussions regarding the front wheel drive 1985 to 2005 DeVille,
1985-1992 Fleetwood and 1993 Sixty Special.
Cadillac Forums: 93 deVille exterrior door handle
Old 03-10-07, 01:34 PM
Cadillac(s): 1993 Sedan de Ville
View Awfulnice's Photo Album
Casino Cash: $670
When i push in the drivers door handle nothing happens, but on the passenger side the whole interrior lights up. My gas station guy says there is a switch inside the handle. So i have to find a handle somewhere, take the door apart, put the handle on and hope that the switch works. Could this be true?? Thanks for any help.
  #2 (permalink)
Old 03-10-07, 03:12 PM
thu's Avatar
thu thu is offline
Cadillac(s): 2003 STS, 1993 Deville, 1985 Deville
View thu's Photo Album
Casino Cash: $2365
Re: 93 deVille exterrior door handle
I have the 93 Deville FSM (Factory Service Manual). There is a wire hooked up to the outside door handle. I don't know if this the related to the courtesy lamp feature, but it looks like it.
To remove the outside door handle:
- Glass must be fully up
- remove trim panel
- remove water deflector. This is secured to the door inner panel with pressure sensitve tape located on the outboard surface of the deflector. This allows the deflector to be peeled back as needed to service door components.
- remove rod from the latch
- remove wire connector
- remove screws
- remove handle
It could be that the wire has fallen off or is corroded. After you have the handle off, a couple of simple tests will determine if it's the switch, wire, or something else.
Good Luck.
  #3 (permalink)
Old 03-11-07, 03:34 AM
Casino Cash: $670
- remove trim panel
- remove screws
- remove handle
Good Luck.
Thanks for the advice thu but i think i'll have to get used to getting into a dark car. Thank goodness for daylight savings time.
Tags: , ,
deville, door, exterrior, handle
attach your bluetooth cell phone to onstar
cadillac key wraps
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
