Procedures for cleaning under the hood
Results 1 to 8 of 8
Cadillac Detailing and Bodywork - Interior and Exterior including Body and Wheels Discussion, Procedures for cleaning under the hood in Item Specific Cadillac Discussion; I've read up on what to use to clean my engine and have decided to use dishsoap and simple Green. ...
    Roswell256's Avatar
    Roswell256 is offline Cadillac Owners Fanatic
    Feb 2004
    Quantico, VA
    35
    285
    QuestionProcedures for cleaning under the hood
    I've read up on what to use to clean my engine and have decided to use dishsoap and simple Green. What I'm looking for is a procedure or maybe a list of stuff that I should clean. now I know I should clean up everything but maybe I should ask the question of what NOT to clean? What is under the hood that should be off limits or what should I stay away from? Is it a good idea to remove the supports and metal bars around the engine to get down in there and really get it cleaned out? Is there anything I should be watching for? Also sence the engine has about 109k on it. What should I take off and clean out to keep it running great? throttle body? EGR (whatever that is)? Sensors, valves, or diaphrams that should be cleaned out or atleast checked for corrosion and debris? Also does anyone know a good way to clean up those two engine stabilizers on the front right and left of the engine? Mine are majorly corroded and I would like to either clean them up or get new ones to help improve the look. My goal is to bring this back to almost new condition. Thanks for the help and look foreward to hearing from all of you.
    P.S. this forum is full of increadable amounts of help and helpfull people. Thank you for your patience.
    -Roswell-
    elwesso's Avatar
    elwesso is offline Cadillac Owners Master
    Automobile(s): 2005 CTS-V, 1994 Infiniti Q45
    Jan 2003
    Indiana
    7,661
    Re: Procedures for cleaning under the hood
    Basically if your doing just a cosmetic clean, then I would spray simple green (full) over all the bay... Dont be too liberal, as a slight mist will take care of it...
    I did it to the 95 wood and it was INCREDIBLE the difference. I spray it on, let it sit for a couple mins, and then misted the engine quite a bit... It was like night and day...
    Its best to do it when hot so it drys faster...
    Just dont go too crazy on anything electrical.. A little shower on everything wont hurt anythign...
    After this, rinse the engine bay every time you wash and you will keep it really clean.....
    This is the procedure i use on my Q...
    elwesso's Avatar
    Jan 2003
    Indiana
    7,661
    If you want to clean stuff I would search the forums for THROTTLE BODY, EGR VALVE, PLENUM, etc...
    Ralph's Avatar
    Ralph is offline Cadillac Owners 10000+ Posts
    Automobile(s): Cadillac
    Mar 2003
    Saskatchewan, Canada
    16,105
    I didn't look to see what your model is, or if it has a distributer cap, but if so I would cover it with a plastic bag to prevent engine stalling. Tie an elastic band around it for a good seal. There used to be some controversy as to whether to keep the engine running or not when flushing the cleaning agent. I was told once to run it, but flush with warm water and not cold because cold might crack the block if the engine is hot! I think that would be rare.
    Night Wolf's Avatar
    Night Wolf is offline Cadillac Owners 10000+ Posts
    Automobile(s): Unicycle
    Mar 2003
    Where I park it
    11,009
    the BEST stuff to clean white walls and clean/drgrease the engine.....
    PURPLE POWER
    stuff is amazing....
    Roswell256's Avatar
    Feb 2004
    Quantico, VA
    35
    285
    THank you all. In the military, so they sell a bunch of simple green. I'm hoping the weather holds out so that I can get to it this weekend. I'll let you know what I find.
    Thanks again
    -Roswell-
    Roswell256's Avatar
    Feb 2004
    Quantico, VA
    35
    285
    No I don't have a distributor cap and I'm just going to take everything that seems unimportant off. Like supports and crossmenbers and clean up everything that I can reach. I'm almost 7ft so that should be most of it. Then I'll take it to the hobby shop and put it up on a lift and clean everything else I can find.
    Thanks
    -Roswell-
    Elvis's Avatar
    Elvis is offline Cadillac Owners Master
    Automobile(s): '05 Expedition
    Jan 2003
    52
    7,651
    Q-tips and windex.
  11. Remove Advertisements
