Headlight Cleaning - Page 2
Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Cadillac Detailing and Bodywork - Interior and Exterior including Body and Wheels Discussion, Headlight Cleaning in Item Specific Cadillac Discussion; I would think 800 grit to be too agressive for this, but no matter. Go with the meguiars plastic polish. ...
  1. #16
    Frost's Avatar
    Frost is offline Cadillac Owners Connoisseur
    Automobile(s): 1988 SDV; 1997 SDV D'Elegance
    Aug 2003
    Ontario Canada
    1,401
    Re: Headlight Cleaning
    I would think 800 grit to be too agressive for this, but no matter. Go with the meguiars plastic polish. I'm not familiar with the 3M brand. If the meguiars polish doesnt' do it, then pick up meguiars FINE CUT cleaner and try that,
    Whatever you do, DON'T PANIC! The headlamp pods will come back, but you have to be diligent in taking the right steps. Always go lighter. First try the meguiars plastic polish/cleaner. If not, then go with the meguiars FINE CUT cleaner. Whatever you find that cleans up the lense and makes them look "crystal" when dry. If you find the FINE CUT cleans it up, then FINISH with the plastic polish.
  2. #17
    Cyberdan3 is offline Cadillac Owners Fanatic
    Automobile(s): 2001 Cadillac STS
    Nov 2003
    31
    154
    ok thanks.
  3. #18
    Nov 2003
    31
    154
    Well I used Plastx and it helped a little bit. I ended up bringing it to a body shop and the guy polished the headlights by machine. They look really good now. He said he only wanted some lunch but I gave him $20
  5. #19
    SL1CK's Avatar
    SL1CK is offline Cadillac Owners Enthusiast
    Automobile(s): 1996 Cadillac Seville STS
    Jun 2005
    Houston, TX
    28
    535
    Did he polish him with the PlastX you had bought?
  6. #20
    Nov 2003
    31
    154
    Nope he used a pink "finishing" compound and buffed with a foam pad. They use 3M products for the most part. But he sure helped fix my problem, since I want clear lights when I get my HIDs. And just a note, I did use some of my bros aluminum and mag wheel polish before i went there and it made it look better.
  7. Remove Advertisements
