Results 1 to 7 of 7
Thread: Windshield Scratch
    Oct 2003
    16
    Windshield Scratch
    One of my windshield wiper blades popped out of the clips at the end of the wiper arm. I heard the scratching sound and pulled off the road and reinserted it. The wiper only made a couple of passes before I fixed it, but left a nice scratch in the windeshield.
    Is there any product out there that I can use to buff this scratch away without causing further damage?
    Any help would be greatly appreciated.
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,299
    Re: Windshield Scratch
    There are a few companies like Eastwood that sells scratch repair kits for glass, I have not had much luck personally with them
    Sep 2003
    1,471
    You may be able to take it out with one of the polishing kits depending on the depth of the scratch. You do have to be careful because a little too much heat from friction and your windshield will distort. Follow the directions carefully and to the T. You can order it from Eastwood or JC Whitney to name a couple of sources.
  5. #4
    Feb 2004
    Michigan
    30
    7
    I use 0000 or 000 steel wool and lightly rub it out like you were rubbing out a scatch in your paint. I know it soudns scary but it works
  6. #5
    highonchai's Avatar
    highonchai is offline Cadillac Owners Fanatic
    Automobile(s): '85 Seville Commemorative, '69 Sedan deVille, '06 CTS Sport
    Feb 2004
    Lansing, MI
    31
    424
    Steel wool, really? I need to do this to my '69 Sed Dev as well, someone let the blades wear down so much that the metal bracket scratches the windshield probably havent been replaced since '69. theres a nice scratched area on that windshield. Do you need to polish the windshield after using the steel wool?:coolgleam
  7. #6
    Feb 2004
    Michigan
    30
    7
    I usually just use windex to clean it off. You can also use Steel Wool for scratches in plastics.
  8. #7
    Sep 2003
    1,471
    Steel wool sounds scary on glass. I would try practicing on my neighbor's windshield first before I tried it on my own. I would stick with the special windshield polishing compound. I used it on a Vette I once owned and it worked great.
  • You may not post replies
