Wire mesh material
Results 1 to 13 of 13
Cadillac Detailing and Bodywork - Interior and Exterior including Body and Wheels Discussion, Wire mesh material in Item Specific Cadillac Discussion; Does anyone know where I can get the wire mesh material like they use for the V style grills?...
    codewize's Avatar
    codewize is offline Cadillac Owners Master
    Automobile(s): 91 Brougham d'Elegance / 95 Fleetwood Broug/ 01 DTS / 11 CTS Lux
    Apr 2005
    Upstate NY
    50
    6,919
    Wire mesh material
    Stoneage_Caddy's Avatar
    Stoneage_Caddy is offline Cadillac Owners 10000+ Posts
    Automobile(s): 01 frontier , 89 Shelby CSX vnt
    May 2003
    Undisclosed location in FL
    14,607
    Re: Wire mesh material
    i saw some in advance auto parts the other day ...check the honda more stickers to go fast section ....
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    Yeah I found some online too. I guess my question is doesn't anyone know the sizing and gauge specs of the actual grills.
    I'm going to be doing some work to the DTS. Vogue has a mesh grill for the car but I want to fill in or at least cover the lover vents between the fog lights with the same material. My effort is to create a DTS-V if you will.
    BTW the grill will not be the only mod.
    FastCTS is offline Cadillac Owners Enthusiast
    Automobile(s): 2003 CTS
    Jan 2004
    Indio, Ca.
    920
    Quote Originally Posted by codewize View Post
    Check with luvmy03caddy in the CTS section he makes lower mesh grilles for the CTS, he should know.
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    Frig, now that I have spoken with Vogue, they're telling me they don't make the grill for the 01. Only 04 and newer. Damn it.
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    Does anyone know what the specs are on the V grills?
    Gauge of steel, spacing, bend types, weld types?
    It looks like I'm going to have to get one made. CAD drawings would be great
    Frost's Avatar
    Frost is offline Cadillac Owners Connoisseur
    Automobile(s): 1988 SDV; 1997 SDV D'Elegance
    Aug 2003
    Ontario Canada
    1,401
    Sorry that I can't help you Codewise, but I DID want you to know that I'll be interested in your end result - on all fronts.
    I've shot my bolt as far as mods for this season and they've pretty well all been appearance related, but next year I'm tackling the performance end of things. I'd like to get a proper cone filter intake set-up, lower the car and stiffen up the suspension a-la Hitmoney's ride and upgrade the brakes. Finally, I want to fill in the opening that stretches across the lower front end of my car - probably with a mesh between the foglights..
    A DTS-V, eh? If you pull this one off, keep all your drawings and specs handy - I have no doubt that there will be a path beaten to your front door by a crowd of DTS owners, wanting the same look and performance!
    CADDYBLACK99 is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 STS-4 1999 Deville Concours
    Oct 2003
    NEW ENGLAND
    57
    1,486
    I came up with this idea back in 2004. Here is my attempt. 99 Concours mesh grille
    I looked high and low and at the time no one made a mesh grille insert for the 99'. I looked at mesh manufactures for mesh fabric and even measured a CTS mesh grill for the weave spacing. Anyway I gave up and ended up attaching it to the backside of the grille and the lower section. The attempt was to add style, but also function (did you ever have road debris fly through your front grille and lodge into the AC conden$er) enough said. Good luck, I'll be watching for the results.
    Paul
    RedGalant2k1's Avatar
    RedGalant2k1 is offline Cadillac Owners Connoisseur
    Automobile(s): N/A
    Apr 2006
    Michigan
    1,108
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    LOL That's the second place i saw with that photo. Those are the ones from Vogue. I spoke with my inside sales rep yesterday and he swears that a grill form an 04 will absolutely not fit into an 01. I'm going to ask him to send me one and return it if it doesn't work.
    The other place I saw was 2000-05 Cadillac Deville Classic Mesh Grille - E&G Classic: U.S. SPEED
    As you can see it's the same photo and the car has vogues on it. That's the actually photo form the Vogue web site.
    Thanks for providing that resource. It may be helpful.
    Automobile(s): N/A
    Apr 2006
    Michigan
    1,108
    I don't see why a 2004 Grille couldn't fit a 2001. The mounting points may be different, such as the header panel or core support, but I'd not suspect much is different if at all.
    Tombo47 is offline Cadillac Owners Enthusiast
    Automobile(s): 2001 ETC
    May 2005
    Levittown, NY
    29
    520
    i dunno man i took an '04 grill and threw it on my '00 DTS
    codewize's Avatar
    Apr 2005
    Upstate NY
    50
    6,919
    No problem. I got to the bottom of it. I went to the source, E&G Classics. According to them the grills are all exactlly the same from 2000 - 2005 so my man at Vogue is wrong.
  16. Remove Advertisements
