INfo 3-m alternative
Results 1 to 3 of 3
Cadillac Detailing and Bodywork - Interior and Exterior including Body and Wheels Discussion, INfo 3-m alternative in Item Specific Cadillac Discussion; ...
    turbomangt is offline Cadillac Owners Fanatic
    Oct 2005
    chicago
    457
    People have been sending me PM’s around a comment I made regarding an alternative to the 3-m film. I heard about it at a professional seminar last year. The process is done using a clear coat with an additive called “Plasticizer”. The molecules in the Plasticizer are tighter than traditional clear coat making it more resistant to stone and rock chips. The shops applying it around here have tested it on cars and the findings are 60% more resistant to chips. Keep in mind if I dime size stone hits your car going 40MPH it won’t help. The effectiveness is in the ability to withstand minor stones without chipping the paint. Cost is about 35% more than the 3-m film, reason is because the areas it is applied to has to be treated just as you would if you were repainting. Hope than helps some. Gary
    Frost's Avatar
    Frost is offline Cadillac Owners Connoisseur
    Automobile(s): 1988 SDV; 1997 SDV D'Elegance
    Aug 2003
    Ontario Canada
    1,401
    Re: INfo 3-m alternative
    How would this system work on door dings, Turbo? Any more effective than straight base/clear?
    Oct 2005
    chicago
    457
    I would think it would be better, although if someone gets out of their car and is inconsiderate enough to slame his/her door into your car, it probably won't help much. From what I understand this system will do fine for the minor chips, but the heavy ones, it will still chip.
