What do u guys think? The lights are an aftermarket replacement for a 92-98 BMW E36. I converted the original Angel EYES (which used regular light bulbs) To 7000K CCFLs. And as u can see, its day time, and they are clearly visible. Ill try to get some nighttime pics on here if i can soon.... I also removed the "popo-style" push bars from the bumper, and replaced my grille with a 2000ETC grille. The headlights took about 8 hours to install. I had to grind into the sub-frame and cut out a lot of plastic. Also, all custom welded brackets had 2 b made to hold the lights in place. The Eldo grille also takes a bit of grinding to fit. Anyway, its still a work in progress and the final fit should b a little cleaner once I figure out what im going 2 do with those hideous corner lamps...any ideas?
yea the tsx projectors are the best around but thats why they are $300, i paid under $100 for my retro including both projectors, plexi for the headlight lenses, and 2 extra deville headlight assemblies
yeah thats really cheap! well i paid 150 for my pair of TSX headlights with the projectors intact. plus the djhousings extra 140 and then 20 and homedepot for misc metal and screws.
I just picked up a salvaged 02 Eldorado from an accident and it needs front end work. Since it needs a fender and new headlights anyway, and after seeing your BMW mods, I think I need to install these BMW E36 headlights too!
Besides welding and molding the fenders did anybody find some corner lights that just fit in easy for the Eldorado? It looks like the Seville corners will fit but not sure.
Just got done with the bmw angel eye install! The only thing that I need to do is just touch up my corner lights. I dont know what to install to fill in the space on the corners (outside border) any suggestions I want it to look neat and decent and I dont know if silicone will do that. Im also considering smoking the corner lights!
Ok Heres the pic.GizmoQ What did you use to seal your signal light outer edges and I see you still have your orange turn signal in, I just trimmed to whole assemble of the org turn signal holster!!!
I hated to loose the (turning) side illumination lamps so I kept the originals and filed them down to fit. I had to create lamp holders and sealed then with duct tape then fiberglassed over it. To hold them in place I drilled a hole from beneath through the accent strip(holds it in place too) into the corner lamp. A 2 inch wood screw is put through the hole and bites down on the lamp housing pulling everything tight. Works real good and keeps everything in place.
My only problem so far is the eyes on the E36 lamps are thin plastic and are slowly cracking under the pressure of my mounts cause they are not perfectly straight.
Hey Gizmo I just bought the e36 lights and upgraded switchback angel eyes I was wondering if you could take a few pics of the inside engine compartment where the lights are. Just need to see little more detailed image of what you did. I have an 01 ETC and I'm puzzled on the corners. Did you grind the grille at all or just the corner lamp. Your eldorado is amazing BTW bad a$s wing
Just joined this Site today, so I hope asking where I can get them is not a newbie mistake. Also Impossible to find the emblem(s) for the front grille of my '94 STS. any idea's anybody? Thanks, SanDiegoRoy.
Just breezing the thread says they are a custom one off piece made by grinding down E36 BMW lights. It doesn't look like there is an 'off the shelf' solution. Hope you like projects!
Related Threads
Cadillac Owners Forum
4.8M posts
369.7K members
Since 2002
