How Serious is Rust?
Results 1 to 7 of 7
Cadillac Detailing and Bodywork - Interior and Exterior including Body and Wheels Discussion, How Serious is Rust? in Item Specific Cadillac Discussion; I knew the '76 Fleetwood I just bought had a little bit of body rust when I bought it (it ...
    TeagueJT81's Avatar
    TeagueJT81 is offline Cadillac Owners Fanatic
    Automobile(s): 1976 Fleetwood Brougham d'Elegance
    Jul 2004
    Knoxville, TN
    30
    186
    I knew the '76 Fleetwood I just bought had a little bit of body rust when I bought it (it had been keyed and the scratches are rusting and there's a little bubbling under the paint behind the back window). I've heard these cars do not have any sort of rust proofing. How long do I have to get this dealth with? I should be getting it repainted within the year, but if that's too long I need to know. If that is too long to wait, what could I do for the short term to at least stop it from spreading?
    Thanks in advance,
    Joe
    Ralph's Avatar
    Ralph is offline Cadillac Owners 10000+ Posts
    Automobile(s): Cadillac
    Mar 2003
    Saskatchewan, Canada
    16,105
    Re: How Serious is Rust?
    Rust is like cancer for your car imo. I would deal with it ASAP. I had to deal with it on my 1980 Pontiac and every year I would have to do areas, but I'm glad I kept rust away because it increases the resale value of your vehicle, etc. if it's rust free...
    addison_ii's Avatar
    addison_ii is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Sedan Deville
    Mar 2005
    Twin Cities, Minnesota
    36
    2,146
    Like Rusty Jones said: If not taken care it will be with you the life of your car. Not a good thing. Like Ralph said: Keep it away.
    Krashed989's Avatar
    Krashed989 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 Eldorado, and a 99 ETC
    Sep 2004
    Hilo, Hawaii
    29
    3,887
    If you can't take care of it now then try to scratch most of it off (Bubbled paint included) and use a crayon on top of it. The crayon is wax so it will keep water out and at least slow it down. Plus it comes in an asortment of colors. Take care of it as soon as you can though.
    Aphix's Avatar
    Aphix is offline Cadillac Owners Member
    Aug 2005
    Lincoln, Nebraska
    70
    I would try to sand off the majority of it and then use bondo or something to cover it up. That way the rust is sealed in and wont get worse.
    brougham is offline Cadillac Owners Master
    Automobile(s): 1991 Cadillac Brougham D'Elegance 5.7 Litre, 1994 DeVille
    Jun 2003
    Canada
    6,494
    If the scratch is that bad that it's rusting just put some touch up paint over it until you get it fixed properly. For that other spot if it doesn't look like it's getting any worse just leave it alone.
    90Brougham350's Avatar
    90Brougham350 is offline Cadillac Owners Connoisseur
    Automobile(s): 94 FWB, 93 SDV, 94 FWB (sold), 90 Brougham (sold)
    Jan 2005
    River Falls, WI
    32
    3,730
    Try POR-15's products. They have an epoxy putty that dries as hard as steel, can be drilled, sanded, filed, and painted, and it will harder under water. Their paint products (as well as a few others) actually use moisture to cure and harden. POR-15 paint was designed actually to be applied on top of rusty metal, it prefers the rough surface.
    Brian
  10. Remove Advertisements
