1992 Brougham milky trim fix?
Results 1 to 9 of 9
Like Tree3Likes
  • 1 Post By jamespowers
  • 1 Post By MoistCabbage
  • 5 Post By jamespowers
Cadillac Detailing and Bodywork - Interior and Exterior including Body and Wheels Discussion, 1992 Brougham milky trim fix? in Item Specific Cadillac Discussion; Tried so far: Neverdull, Mother's Aluminum Polish with Dremel white cloth wheel, #0000 steel wool. Anyone have any experience with ...
    AladdinSane5150's Avatar
    AladdinSane5150 is offline Cadillac Owners Member
    Automobile(s): 92 Brougham d'Elegance(Dark Maple Metallic)
    Jul 2008
    Pennsylvania
    45
    Tried so far: Neverdull, Mother's Aluminum Polish with Dremel white cloth wheel, #0000 steel wool. Anyone have any experience with this?I've heard everything from Easy Off to acid. I'm looking for a fairly painless on-car fix. Thanks in advance!
    jamespowers is offline Cadillac Owners Connoisseur
    Automobile(s): 1986 Brougham, 1975 Eldorado, 2008 Escalade
    Mar 2013
    1,100
    Re: 1992 Brougham milky trim fix?
    Try Wenol
    1915_wenol_1.jpgIt works for me.
    AladdinSane5150 likes this.
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,323
    The trim is coated. You'll have to remove the coating and polish the metal. Unfortunately, the correct/easiest way to do that is with a buffing wheel, with the trim off of the car. I had the same problem on my '89 Custom Cruiser.
    Jul 2008
    Pennsylvania
    45
    Yeah, that's pretty much the gist of what i've been reading. I wouldn't be so wary of that method if the clips weren't so hard to replace when i break one (or ten...)
    Jul 2008
    Pennsylvania
    45
    [/COLOR]
    Quote Originally Posted by jamespowers View Post
    Try Wenol
    So i ordered some Wenol based on the reviews i saw.Takes 2-3 weeks to get here from Thailand...i doubt it will solve my problem,but hope to use it on other metal parts.
    Mar 2013
    1,100
    Quote Originally Posted by AladdinSane5150 View Post
    [/COLOR]
    I hope it works for you. It works wonders for me.
    Jul 2008
    Pennsylvania
    45
    I'm gonna try a little section this weekend.Might hit it with some 2000 grit first to get through the coating(I may have to go finer), then Wenol after that.At any rate, "The Godfather" gets put in storage off property for the cold and road-salt laden PA winter on Tuesday. I will report my findings!
    Mar 2013
    1,100
    I have used super fine steel wool with Wenol and that works fairly well. It will gunk up a pad with all the junk you get off with it.
    Jul 2008
    Pennsylvania
    45
    Thanks, James. I picked up some #0000 recently.
  12. Remove Advertisements
