Sustained Preservation (Exterior Maintenance)
Results 1 to 3 of 3
Cadillac Detailing and Bodywork - Interior and Exterior including Body and Wheels Discussion, Sustained Preservation (Exterior Maintenance) in Item Specific Cadillac Discussion; Suggested Regiment for Vehicle's Exterior Life and Luster. I wash my Seville with "hot-water," windshield and glass with "cold-water." Metal ...
    curtis7251 is offline Cadillac Owners Member
    Sep 2012
    1
    QuestionSustained Preservation (Exterior Maintenance)
    I wash my Seville with "hot-water," windshield and glass with "cold-water." Metal is always maintained with "hot-water" and Crystal is also best maintained with "cold-water." Therefore, I suggests the entire body of the auto should be washed in "hot-water" and all glass and plastic related substance with "cold-water."
    The Tires and Wheels are also to be washed with "hot-water" employing your choice of chemical to achieve the results you desire maintaining exterior luster. This continued regiment will help maintained the Factory Luster and long exterior "Body-life" of your automobile.
    Also, to address the free radicals that are embedded in the "Rubber" around the windshield, rear window, trunk and doors, I suggest you apply a Cleaner De-greaser or WD-40 De-greaser to eradicate the free radicals that are lodged within the rubber around the windows, windshield, doors and hood.
    Hot-Water? Yes, I boil a kettle of water on my Stove-top, place it in a five (5) gallon container adding additional hot water from my Tap in the kitchen. That's been my secret in maintaining Factory Luster on my beloved Seville!
    Hope you will employ and enjoy the benefits?
    Wellington
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,840
    Re: Sustained Preservation (Exterior Maintenance)
    Moved to Appearance - Detailing
    ANY "cleaner-degreaser" such as Brakleen, throttlebody cleaner or electronics cleaner will positively EAT the rubber window/windshield surrounds......... and WD-40 is, by its very definition - 'greasy'.
    Not sure if this is legit advice or not - it seems a bit off the wall ............... and an exact duplicate post was just deleted from Classic Cadillac.
    curtis7251, Please do NOT post multiple identical threads in different forums. Once more and you're spamming.
    basscatt's Avatar
    basscatt is online now Cadillac Owners 10000+ Posts
    Feb 2004
    Minnesota
    65
    15,349
    I smell a
    when washing the roof -
    how do you keep the hot water off the glass -
    and when washing the windows -
    the cold water off the doors? -
    do you RINSE after washing?
    if YES - do you RINSE the car with HOT water -
    and the glass with COLD water?
    REALLY?
    so - how much hotter does the water get
    by adding 1 kettle of boiling water
    to 5 gallons of hot tap water -
    isn't that too hot to put your hands into?
    do you use soap?
    DAMN THOSE FREE RADICALS -
    they shouldn't be allowed to run around free -
    they should ALL be gathered up - and DEPORTED -
    I don't think we have to KILL them all -
    just send them back to where they came from -
