Bird crap leaves a milky-like outline?
Results 1 to 13 of 13
Cadillac Detailing and Bodywork - Interior and Exterior including Body and Wheels Discussion, Bird crap leaves a milky-like outline? in Item Specific Cadillac Discussion; New Caddy ATS (Glacier Blue). When bought, I detailed with Zaino, been using it for years. Anyway, here in south ...
    flycaster's Avatar
    flycaster is offline Cadillac Owners Enthusiast
    Automobile(s): 2013 ATS 2.0T AT Lux, 2017 MB C300 Coupe
    Mar 2013
    Boynton Beach, FL
    78
    910
    New Caddy ATS (Glacier Blue). When bought, I detailed with Zaino, been using it for years. Anyway, here in south Florida, one is always getting bird crap on the car. 99% of the time, if I can get to it early, it will simple wipe off; but sometimes, it will leave an milky-like outline of the dropping. Mild rubbing compound, 3M scratch remover, Zaino AIO...nothing gets the crap off. It is only seen when one looks at it from a low angle. I would appreciate it someone can help me.
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,840
    Re: Bird crap leaves a milky-like outline?
    Problem is, bird droppings actually etch the clearcoat - physical damage. See if the tech links in www.autogeek.net have any advice.
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    910
    Thanks, Submariner. You are quite right about the etching characteristic of bird crap. I have been on several other detailing forums and some feel that the etching can be significantly reduced by using Menzerna FG400 polishing compound...see this link (http://www.detailingworld.co.uk/foru...d.php?t=314534).
    Although Menzerna FG400 was suggested, could Meguiar's M10508 Ultra Cut Compound be used instead?
    6lbsofSound is offline Cadillac Owners Fanatic
    Automobile(s): 03 Escalade
    Aug 2012
    193
    Either the Meg's or Menzerna should work, I would use a DA with an orange pad to start and step up to yellow if that doesn't work.
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    910
    Quote Originally Posted by 6lbsofSound View Post
    I will have to do this by hand and would appreciate suggestions on how to go about it. I'm specifically interested in knowing: 1) If I can get some kind of hand-held pad to "rub" the stuff with, or would a MF cloth be OK, and 2) The etching is only about 1.5" in diameter and sits on top of the hood (so I don't want to screw up and make a visible mess), using a pad or a cloth, how much pressure should I exert and what motion should be used...circular, straight back and forth...?
    Feb 2006
    55,840
    Look at the "Polishin' Pal" handheld set in www.autogeek.net............. but you'll also need some fine cut swirl compound as well as a sealant and/or wax.
    For this job, a MF cloth wrapped tightly around your first two fingers and swirl compound applied like spit-shining a shoe should do it - just don't get carried away - clearcoat is only so thick (thin).
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    910
    Quote Originally Posted by Submariner409 View Post
    I plan on using one of these compounds to remove the etching; whichever one I can get locally.
    Meguiar's M105 Ultra Cut Compuond
    Meguiar's Ultimate Compound
    Menzerna FG 400 Fast Gloss Compound
    I know there are hand-held foam rubbing tools, but if the MF cloth does the job, OK with me; although I have to admit that I haven't spit-shined in about 50 years.
    Thanks.
    Aug 2012
    193
    Meg's makes a drill attachment that functions like a DA might be worth the investment for spot situations like this and future touch ups. Your process is good I don't think even if you use a proper foam polish pad by hand it will take it out. Removing etches like this by hand are really tough. M105 should be a good starting point that you can get the big box auto stores.
    ELDORADO2K is offline Cadillac Owners Member
    Feb 2005
    Los Angeles,CA
    27
    Once you get it off, I recommend using the Armor All Extreme Shield Wax. Armor All gets alot of crap but I recently finished off my complete paint correction with this wax and bird crap is no match for the protection it leaves. It washes right off even after sitting for 2-3 days. I've found those "boutique" waxes are mostly best at costing a bunch of money while having minimal lasting time and providing delicate protection... The real shine comes from the steps made prior to waxing. So IMO those high priced waxes amount to crap product as they can't even protect from measly bird crap. Get the shield wax. Trust me, the stuff protects like nothing I've tried b4. Toss that Zaino crap and save the cash.
    cdog533's Avatar
    cdog533 is offline Cadillac Owners Enthusiast
    Automobile(s): 2010 CTS-V
    Apr 2004
    539
    You can't do this by hand.
    You need a DA polisher like a Porter 7424 a 5" backing plate, a 5" Lake County CCS Orange Pad, and a 5" Lake County CCS White pad. And Meguiars M105 and M205, which you can actually source locally at an Advance Auto Parts.
    Watch the videos on autogeek.com and learn how to correctly polish a car. Try the white pad and 205 on the bird poop etch. If that doesn't work, try 205 on the orange; if no go then 105 on white, if no then 105 on orange.
    If you use the 105, you'll need to polish the haze it leaves the 205 on the orange... then hit it soft with the 205 with the white. Then rewax it. Sounds like a lot; only takes 15 minutes.
    Really, no wax will protect against bird droppings due to their acidity. Best thing to do is get them off quickly. As far as products go, everyone has their preferences, but Zaino seems to be a favorite. Personally, I use a sealant-type product topped with a carnauba wax.... I think Zaino has a similar setup.
    flycaster's Avatar
    Mar 2013
    Boynton Beach, FL
    78
    910
    All good advice. However, I don't think that I'm going to get involved with a PC as it seems that I have been able to get rid or the etchings by hand-power. However, I do have a question: Assuming that I have 2 etching spots on the hood, would I have to PC the whole hood to get it right; or, would just PC'ing the two individual spots be OK? I'm thinking that if I were to PC just the two spots, then when looking at the hood one would see a difference in color shade (my car is maroon) where the spots were done???
    Feb 2006
    55,840
    A DA polisher, swirl remover, different pads will do such a good job of smoothing the etching area that the rest of the panel will look dull buy comparison.
    I would use something like the Autogeek Polishin' Pal (hand job) to work out the localized etching and, using an extremely fine swirl removal liquid and minimum cut pad on a DA - polish and wax the entire panel.
    It's www.autogeek.net
    MoistCabbage's Avatar
    Sep 2010
    East Boston MA.
    29
    26,325
    I use a Dewalt rotary buffer and Presta polishing priducts, then hand wax.
    One day I'll get one of these for waxing/cleaning and see how it polishes compared to the high speed rotary:
    http://cyclotoolmakers.com/Model_5Pro.php
  16. Remove Advertisements
