22s on 96 cadillac
Results 1 to 3 of 3
Cadillac Detailing and Bodywork - Interior and Exterior including Body and Wheels Discussion, 22s on 96 cadillac in Item Specific Cadillac Discussion; Does anyone know if 22s will fit on my 96 cadillac sedan deville with out using a lift and if ...
    benjam is offline Cadillac Owners Member
    Automobile(s): 1989 cadillac fleetwood fwd
    Dec 2012
    32
    6
    22s on 96 cadillac
    Does anyone know if 22s will fit on my 96 cadillac sedan deville with out using a lift and if i do have to lift it does the air ride suspension have to be swapped out for regular suspension please help thanx
    Submariner409's Avatar
    Feb 2006
    MD Eastern Shore, Kent Island
    55,840
    Re: 22s on 96 cadillac
    Your Deville does not have "air ride". It uses an Automatic Level Control to compensate for extra weight in the rear seat or trunk - defeat it and the rear sags. ALC/ELC is separate from the suspension control.
    Let's say that your original tire size had a 27" outside diameter. As long as you keep that tire OD you can put any size wheel on the car and suffer no suspension problems as long as you're careful with treadwidth and section width to prevent fenderwell rubbing in turns.
    Going to excessively large wheels creates a problem or two: With 16" wheels and a 27" tire OD there is 5.5" of air/rubber between the wheel and road. With 22's there is 2.5" of air/rubber between the wheel and the road: ride and handling suffer. Go to a larger OD tire to recover a bit of ride comfort and the larger tire diameter changes speedo readings, engine load management and transmission shift points.
    Cadillac Kid03's Avatar
    Cadillac Kid03 is offline Cadillac Owners Connoisseur
    Automobile(s): 2003 Cadillac Seville SLS
    Mar 2011
    Tinton Falls, NJ
    24
    1,299
    Please don't put 22"'s on your Deville that's all.
