Clean up of Tire shine
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Cadillac Detailing and Bodywork - Interior and Exterior including Body and Wheels Discussion, Clean up of Tire shine in Item Specific Cadillac Discussion; Help, I just purchased a 2005 white diamond escalade and now I have what I think is tire shine on ...
    Kenn is offline Cadillac Owners Member
    Oct 2004
    33
    Cleanup of tire shine off white diamond escalade
    Help, I just purchased a 2005 white diamond escalade and now I have what I think is tire shine on the lower body that is not coming off, even with tar remover. Anyone know what I could use to get this yellow mess off my new ride, and where I could get it. Im in Chicago. Thanks guys. Also I paid $58,000 for a fully loaded 2005 was that a good deal.
    Korn00 is offline Cadillac Owners Member
    Feb 2004
    32
    Re: Cleanup of tire shine off white diamond escalade
    Sounds like you got a really good deal on a fully loaded Escalade. Question is why are you posting this question in the CTS Forum? As far as the tire shine I would have the dealer take a look at it for some suggestions or a car detail place.
    suckit is offline Cadillac Owners Fanatic
    Aug 2004
    312
    What's tire shine?
    ALLeyez187onME is offline Cadillac Owners Fanatic
    Aug 2004
    384
    From my experience tire shine came off with a little scrub with car soap and water, if not it came off with wax. It sounds like you dont have tire shine on your body because i have never seen a yellow tire shine, it may be a type of paint or even glue. Try telling the dealer about it and see what they can do, if not take it to a good body and paint shop and have them take a look at it.
    hcvone is offline Cadillac Owners 10000+ Posts
    Automobile(s): 2012 Escalade, 2014 SRX
    Apr 2003
    H.V., Pa/Town of Webb, NY
    13,299
    Depending on what type of tire shine they used I would first try claying, but you will probably need a product with abrasives like 3M Scratch and Swirl Remover, some dealer tire products will etch into your clear coat.
    Oct 2004
    33
    Thanks guys, Im new to this and I dont know why I was in the forum. Tire shine is the tire dressing they put on for that shiny look. I think that whats on the lower part of my lade, because only noticed it after my car had been washed.
    Apr 2003
    13,299
    Quote Originally Posted by Kenn
    On your next car do yourself a favor and do not let the dealer do anymore than take the plastic off the seats, it's more work but you know it will be done right
    rollman's Avatar
    rollman is offline Cadillac Owners Fanatic
    Automobile(s): STS
    May 2004
    Phila Pa
    174
    If you think this happen from the dealer go back and see if they use a yellow tire shine or possibly something else they used . A good cleaner type polish should remove it if nothing else you tried has . Don't forget to apply what ever protectant (wax or sealant) you use over back on the area you clean to pretect the finish . Good luck and let use know how you make out
    Pifemaster is offline Cadillac Owners Member
    Aug 2004
    Slippery Rock, PA
    20
    Kenn, Did you ever find a fix for these dots? I have the exact same problem on my White Diamond Lade. They seem to be dots about a 1/16" - 1/8" in diameter. They almost appear to be a yellowish stain. I tried to Clay Bar them to remove them, with no sucess. I do not think it is from tire shine, since I only use Zaino's tire gloss. What ever it is, they seem to be increasing in quantity. I originally saw 1 or 2 dots. Now I have about 15 - 20.
    Thank you,
    Bob
    Sandy's Avatar
    Sandy is offline Cadillac Owners Master
    Automobile(s): '93 Cadillac 60 Special; '03 Lincoln TownCar Limited ED
    Oct 2003
    Northern New Jersey
    70
    5,929
    They used Armor All the white-trash of all products! It tells alll about it on the Grand Prix (Pontiac) board, and there are also warnings on it over on the Mark 8 board. The area will have to be re-painted, as there is nothing that will remove it. One guy had the area wet sanded and it still would not come off. Never but never use any armor all product. Urinating on your car would be better! The yellow spots are from the armor all oils, mixing with the tire (rubber) oils that then dry. Then in rain or wet roads, the armor all splashs off and onto the rocker panels that are plastic (rubber) and the oils penetrate INTO the plastic panels staining them with the oils uses in making the tire (rubber) and that penetrates the plastic (painted-rubber) panels on your truck. People on the Mark 8 board have posted a WARNING under car care section http://www.mark8.org and same thing on the Pontiac Grand Prix board. It's the worst & most visable on white cars and light blue cars.
    Apr 2003
    13,299
    You may have run through an area on the road that walnuts from a walnut tress have fallen on, at our shops we have seen this before, and in fact it happened to me with a white Grand Cherokee I owned years ago, and it etched the paint behind the rear wheels.
    Oct 2004
    33
    Well Sandy, you had it right. Spoke to the auto detailer at my dealer and it seems like Armour All was the problem for the black spots I have on my White Diamond Escalade. The shine and the black rubber tires splashes on the bottom part of the lade and spots it up. He said to avoid this is to wipe the shine off instead of leaving it on wet. He was able to get the spots off by steam cleaning it. It looks great now. The yellow stains were from the protective sound guard that I had put on. You all with the white diamond lade watch out for the Armour All, dont go thick on any tire shine. Thanks guys for your comments.
    Kenn
    RBraczyk's Avatar
    RBraczyk is offline Cadillac Owners Connoisseur
    Jan 2004
    Amherst, NH
    29
    4,178
    Re: Clean up of Tire shine
    Yea, tire shine does not like to come off of anything. Especially the damn tires. And when you use it too much, it looks gross.
  16. #14
    Apr 2003
    13,299
    I can tell you no matter how many times you wipe off Armour All it will still fling down the side of your car or truck, there are several better choices.
  17. #15
    an01sts is offline Cadillac Owners Fanatic
    Oct 2004
    MD
    59
    261
    I like the looks of tire shine, but all of it is really nasty crap. They are all nasty. I use it only on occasion if I cannot get the tires clean, but because all tire shine is so nasty, I live with the natrual, but detailed tire look.
  18. Remove Advertisements
