Results 1 to 5 of 5
Thread: Rubberized Undercoating (for wheel wells) - any cons?
    lbwd is offline Cadillac Owners Connoisseur
    Automobile(s): 1996 STS (181,000) Arnott Struts, 245/45/ZR18, 1" Drop -SOLD
    May 2006
    Missouri
    1,589
    I want to make my wheel wells look more black instead of the faded black they are now. I own a 1996 Seville STS and have heard about this rubberized undercoating that auto detailers use.
    Are there any big cons or anything I should watch out for? What about other areas that could be undercoated--are there any?
    Thanks in advance.
    superprohero is offline Cadillac Owners Member
    Automobile(s): 04 Cadillac CTS
    Jan 2010
    23
    Re: Rubberized Undercoating (for wheel wells) - any cons?
    I've been in a body shop for years and we used to use rubberized undercoat especially to cover up paint overspray in the wheel wells and on frame rails. Now we tape and paper everything off better.
    It's OK for applying over steel wheel wells such as in the rear but I wouldn't spray it on plastic wheel wells/splash shields because it will not stick long term and once it starts flaking off it looks crappy.
    You're better off to use a really good cleaner like Blue Max from Car Brite and scrub them, then coat them with Armor All or some other detailing slick stuff.
    If you do go with undercoat I would use a good brand like 3M.
    May 2006
    Missouri
    1,589
    Thank you, superprohero. I think I'll take the cleaner and slick coating route.
  5. #4
    creeker is offline Cadillac Owners Connoisseur
    Automobile(s): 1992 eldorado. 2007 dodge magnum hemi r/t
    Nov 2005
    roberts creek b.c. canada
    3,013
    For an inexpensive black dressing for front wheel wells I have used stove pipe black liquid, I wouldn't even call it paint,it's
    like water,and it does a good job, very easy to apply.
  6. #5
    K@ddiD@ddi's Avatar
    K@ddiD@ddi is offline Cadillac Owners Member
    Automobile(s): 2000 Deville
    May 2009
    41
    89
    Yea under coating doesnt work well on plastic its supposed to be rubberized so it flexes but it still flakes, unless you clean the plastic really well, then sand it rough and use plastic self etching primer, then the undercoat.....too much work for that, clean plastic looks better
  • You may not post replies
