Any way to clean my smoke-damaged vinyl above the ash-tray? *'93 Deville*
Results 1 to 5 of 5
Cadillac Detailing and Bodywork - Interior and Exterior including Body and Wheels Discussion, Any way to clean my smoke-damaged vinyl above the ash-tray? *'93 Deville* in Item Specific Cadillac Discussion; What would be the best way to get rid of this smoke-stain left by the previous owner, who it seems ...
    CarpiversoN is offline Cadillac Owners Member
    Automobile(s): 1993 DeVille 4.9L
    Mar 2009
    21
    ArrowAny way to clean my smoke-damaged vinyl above the ash-tray? *'93 Deville*
    What would be the best way to get rid of this smoke-stain left by the previous owner, who it seems left burning cigarettes in the left ash-tray, and the smoke just steadily trailed up and over the years this happened.
    (taking a picture now, will upload in ~5 minutes)
    delerium75's Avatar
    delerium75 is offline Cadillac Owners Fanatic
    Automobile(s): 1991 STS, 1992 Fleetwood, 1987 Maxima wagon
    May 2008
    Bay City, MI
    42
    276
    Re: Any way to clean my smoke-damaged vinyl above the ash-tray? *'93 Deville*
    I'd try rubbing or denatured alcohol. But be careful...there is a chance either (the denatured alcohol more so) could take the color up along with the smoke stains.
    Mar 2009
    21
    Tried it with some 91% isopropyl that I already had under the sink, but it didn't work at all. =\
    nicktime is offline Cadillac Owners Member
    Automobile(s): 1997 Cadillac Seville SLS
    Dec 2006
    Port Huron, MI
    22
    Try some regular GoJo hand cleaner. A few years back, a friend had his 1967 Olds 442 Dash pad resurface. The place that did it recommended actually using GoJo to clean and protect the vinyl. Since then, I've used GoJo (or equivalent) to clean up factory carpeting and just about anything else of really tough stains..........even pulled windshield sealant "spilled" from a replacement job from the carpeting that the shop was careless about. Good luck.
    jeffrsmith is offline Cadillac Owners Fanatic
    Automobile(s): '99 SLS, '05 Deville, '87 Porsche 944
    Dec 2007
    Ledyard, CT
    57
    299
    I would think the reason why GoJo works as well as it does is that it contains lanolin, actually any of the lanolin based hand cleaners should work just as well. Lanolin is a wonderful cleaner and works well on
    Pressure sensitive label adhesive (after the label itself was removed)
    Gasket sealer
    Road asphalt and tar
    Latex house paint
    Splattered bugs
    Dried but not cured spray can enamel
    You would need to use a brush with some of these but the stuff works wonders, it would definitely worth a shot.
  8. Remove Advertisements
