My LED Bulb Conversion
Results 1 to 10 of 10
Cadillac Detailing and Bodywork - Interior and Exterior including Body and Wheels Discussion, My LED Bulb Conversion in Item Specific Cadillac Discussion; I recently replaced my tail lamps as well as my front turn signals with LED bulbs. I tried several bulbs ...
    dirt_cheap_fleetwood's Avatar
    dirt_cheap_fleetwood is offline Cadillac Owners Master
    Automobile(s): 1990 350 Brougham (The cruiser), 1988 Mark VII LSC (The DD)
    Aug 2007
    Woodridge, Illinois
    27
    5,545
    I recently replaced my tail lamps as well as my front turn signals with LED bulbs. I tried several bulbs from different sites, including superbrightleds.com and the ones I got from Autolumination.com are by far the best. They are the Eagle-Eye Tower bulbs and have one 3 watt LED facing out the end and 10 high power LEDs facing outward to fill the lens.
    These bulbs are plenty bright and I believe them to actually be brighter than the standard incandescent ones. They fill the lens perfectly and look completely original. I did have to change the flasher to run all LEDs but that took like a minute to do. I could have kept the original one if I had incandescent bulbs up front but I don't. The video isn't to sharp but the lights are instant on/instant off.
    [YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/12njzTH03uQ&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/12njzTH03uQ&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
    [YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/F9nFGAnbTac&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/F9nFGAnbTac&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
    Ville94 is offline Cadillac Owners Member
    Automobile(s): 1994 Cadillac Deville
    May 2009
    28
    29
    Re: My LED Bulb Conversion
    Could I ask what you are using for a License plate bulb!!!! that is a gorgeous color!!
    Brizzal's Avatar
    Brizzal is offline Cadillac Owners Enthusiast
    Aug 2007
    West Palm Beach, FL
    28
    847
    very nice! not bad for plug and play bulbs
    Aug 2007
    Woodridge, Illinois
    27
    5,545
    The license plate one is from SuperBrightLEDs.com and is just a standard white LED bulb. They have a better selection of the smaller bulbs and they have a few that shoot 360 degrees like the one I bought.
    May 2009
    28
    29
    How many Of those bulbs are in that assembly? 1 or 2? My deville only has one? Would you still suggest me get one? Is it that large of a difference?
    Aug 2007
    Woodridge, Illinois
    27
    5,545
    Mine has two but I would highly recommend these bulbs. Even if it is just the one it will fill the entire lens nicely. Your DeVille should have two, most Caddys did.
    May 2009
    28
    29
    I thought the same thing, but it truly only has one. I sware! I was Very surprised by that myself. Oh, Yeah, I meant to ask. If I change Just my front Parking lamps/Turn signals to LED's will I have to change the flasher to an Electronic Flasher instead of a thermal? What do ya think?
    Brizzal's Avatar
    Aug 2007
    West Palm Beach, FL
    28
    847
    its 2 bulbs and a 194 bulb, that is the marker light
    Aug 2007
    Woodridge, Illinois
    27
    5,545
    If you convert all the turn signals to LEDs you will need to change the flasher. I got mine from Superbrightleds.com for $12, a fully electronic ones. You have to be careful though because the "electronic" flashers you can buy at Autozone are not truly electronic, they still require some resistance (aka you would need a conventional bulb somewhere in the system). If you only change the back or only change the front you will not need a new flasher.
    However, changing the flashers are not hard. GM puts the flashers right next to the steering column so all you have to do is remove the lower dash cover (usually about 5 screws that takes about a minute to do). The downside with the flasher I bought is that it does not make a clicking noise. It is perfectly silent, but I like it that way.
    sjfnj's Avatar
    sjfnj is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Oct 2008
    Bergen county NJ
    53
    15
    Nice job.
    I'm thinking of doing the same on my 94 Seville SLS
  13. Remove Advertisements
