Body work on the rear wheel well
Results 1 to 2 of 2
Cadillac Detailing and Bodywork - Interior and Exterior including Body and Wheels Discussion, Body work on the rear wheel well in Item Specific Cadillac Discussion; yo all i have 17 inch 100 spoke rims on my 93 deville, and they rub (just on the back ...
    Ghostface88 is offline Cadillac Owners Member
    Automobile(s): 93 Sedan de Ville
    Mar 2008
    North Carolina
    28
    18
    yo all i have 17 inch 100 spoke rims on my 93 deville, and they rub (just on the back 2 wheels) because the on the opposite of the chrome piece on the rear wheel well, it has a lip that sticks in. i am looking to get this laser cut off or some shit like that. anyone had similar problems??? here is my car...
    Presidentiallac's Avatar
    Presidentiallac is offline Cadillac Owners Member
    Automobile(s): 93 Deville
    Jan 2013
    California
    3
    Re: Body work on the rear wheel well
    I had the same problem that your talking about. I found out that my air bags in the rear were not pumping up all the way. As soon as i replaced the o-rings in all the connecters of the air lines the car pumped up to the right height. Becuase there was so much air leaking they would not pump to the right hieght. And they would leak more when i would go over a bump becuase the pressure is stronger in the system when the suspension is compressed. Check your connectors with soad and watr in a spray bottle to check for leaks. Im sure youll find some if the o-rings have never been replaced. Just a tip: there is a T connect under the car on the passenger side towards the back of the gas tank that is over looked very easy. There are 6 o-rings in this connector were main air line branches out to the individual air bags. There is 16 small orings and 1 large oring in the system total. Check it out!
