Page 2 of 2 FirstFirst 12
Results 16 to 28 of 28
Thread: How To Clean The Exhaust Tips (Eldorado)??
  1. #16
    kcnewell is offline Cadillac Owners Connoisseur
    Jan 2003
    Nevada, Still the land of the free!
    2,235
    Gumout Carb. cleaner or Berrymans Chemtool spray or BrakeKleen or any number of other brands available at your local auto parts store in the cleaning section.
  2. #17
    Jan 2003
    Newtown, PA
    58
    6,472
    Carb cleaner is far stronger than Brake cleaner for getting carbon deposits off. You can buy it in any parts store. You can also use throttle body cleaner too. If you use brake cleaner, it will leave less residue than carb cleaner and dries very quickly, but just doesn't cut the crud as well.
  3. #18
    Feb 2003
    Ohio
    59
    Chuck, if you have "carbon" on the outside of your 1 year old mufflers, they might be shot. I can see where "carbon" looking gunk would be on the inside of your tips. If it's on the outside of the tips, does it burn a lot of oil, smoke like crazy. Where's all the "carbon" coming from?
  4. #19
    Chuck C's Avatar
    Chuck C is offline Cadillac Owners Connoisseur
    Jan 2003
    NE Ohio
    1,531
    lol, i never said i had any carbon on my mufflers!
  5. #20
    Feb 2003
    Ohio
    59
    That's what I thought!!!!! I was trying to understand how carb cleaner would come into play as per your question. BTW nice looking ride! I got a spoiler on mine too, but it has a LED light strip in it. I got it from Roman Chariot in Cleveland.
  6. #21
    Jan 2003
    Newtown, PA
    58
    6,472
    Was THIS not the question?
    "Any way to clean off the black/red/brown gunk on my mufflers and tips?? "
    That "gunk" as you refer to it, is a mixture of carbon and rust. And rubbing it with a little "carb cleaner" will remove the deposits. After that, I would suggest some polish.
  7. #22
    Jan 2003
    2,235
    OK Gang, We've obviously got a lot of time on our hands here....'Cause we're pickin' nits here!......But I like it!
  8. #23
    Feb 2003
    Ohio
    59
    Well I guess I just didn't understand that he wanted to clean the inside area of the tips. And thanks, for the explanation of the "gunk", it was most useful. That would be kicking up detailing a notch, cleaning the INSIDE of the exhaust tips. I never thought of that.
  9. #24
    Jan 2003
    2,235
    I use Carb. cleaner to clean out exhaust tips all the time. I really catch a lot of crap from my friends about it 'cause they think it's excessive....But they always come to me for detailing tips!
  10. #25
    Feb 2003
    Ohio
    59
    KC, I cleaned the inside of the drag pipes on the pan I used to have. But the Eldo tips are a different story, they aren't "looking" at you, like on a bike. But, I'll check it out when it gets warmer, maybe mine could use it. Carb cleaner, huh, now if only I knew how to use it. ROTFLMAO I gotta go and clean the litter box, The cats been busy....
  11. #26
    mnymaker's Avatar
    mnymaker is offline Cadillac Owners Fanatic
    Automobile(s): Seville STS
    Mar 2003
    Arlington, VA
    108
    Just finished cleaning up my tips on the Caddy and I used some Gunk Engine Bright and one of those little scrub brushes you use to clean your rims (Yellow, plastic steel wool looking thing in a wedge shape) you can get it at any parts store. Well anyway sprayed that on and rinsed then hit it lighty with the brush and the grime just fell off, I will put a coat of wax on them tomorrow to keep the grime from sticking as much next time but they look about 75% better (not new but shiney again)
  12. #27
    Mar 2003
    Indianapolis. IN
    31
    17
    My dual duals on my 92 seville were really bad, to the point if I RUined them tring to get them clean, I would have got new ones... But I used a brillo pad to get the things started then I windexed them. Total time - 25-30 minutes Looking alot better, time well spent
  13. #28
    Chuck C's Avatar
    Jan 2003
    NE Ohio
    1,531
    so does most of that gunk come off? i remember my original mufflers were so bad that they had huge rusted out holes. Shoot, I saw a new Envoy and the whole muffler and exhaust were rusty...couldn't have been more than two years old. Why don't they just install stainless ?
  • You may not post replies
