Results 1 to 11 of 11
Thread: Smell in interior
    Apr 2004
    100
    Smell in interior
    About a month ago I was transporting some dogs in my vehicle. Well now I have this smell in my car that will not go away. I have sprayed the inside down and even took it to a detail shop. But the smell is still there. Does anyone know any good carpet/upholstery seat cleaners. The guy at the detail shop said that the smell soaked down to the foam under the carpet The smell I have is a mix of wet dog and clothes that have not had the chance to dry. HELP
    Kev's Avatar
    Kev is offline Cadillac Owners 10000+ Posts
    Automobile(s): 1989 Sedan DeVille is now just a fond memory ....
    Aug 2004
    Left Coast (Central)
    57
    10,427
    Re: Smell in interior
    Quote Originally Posted by Fleetwood Blaq
    The first thing you need to do is allow the interior to dry completely. As long as it remains moist the smell will remain as well. Fresh air, some sunlight and time are your best allies here. Once it has dried completely you can try some products such as Fabreez to help further clean up the odor. Worst case would be to remove the seats and carpets to allow drying/cleanup but that would be a lot of work and you may have trouble getting the carpet back in place neatly.
    Jul 2005
    6
    hey buddy, i kinda have the same problem as you but the rear end of my escalade is burnt from somebody trying to blow it up!!....I have the smell of gasoline and smoke and it has soaked right into my carpets/foam and leather interior...i am fighting with my province because they say they can deoterize the carpet and it will smell fine after , i know it will not! Let me know if u find a way to clean it!
    stressed out....
    kd
  5. #4
    Jul 2005
    6
    another thing my truck has sat at a compund for the last month with no rear window and it has rained buckets in there and the SMELL IS STILL THERE....it smells like a gas can with a bit of smoke! I dont think airing it out will always help!! but u never know until u try!
  6. #5
    illumina's Avatar
    illumina is offline Cadillac Owners Connoisseur
    Automobile(s): '98 Buick Regal LS - '91 Caddy Seville - '87 Caddy Seville!
    Feb 2004
    The Empire...
    4,425
    It isn't just a smell, it's a presence...It's an entity...It's the Beast!
    Are you able to take the seats out, disconnect any electrical parts, and then wash them down and then let them air out overnight? That might work out.
  7. #6
    turbojimmy's Avatar
    turbojimmy is offline Cadillac Owners Connoisseur
    Automobile(s): 1994 Fleetwood 60" Stretch; '07 Avalanche, '95 Nighthawk
    Apr 2004
    New Jersey
    3,963
    I had the same problem in my Exploder after I transported my sister's dogs. It was unbelievable. It would NOT go away. After many soakings of Febreeze the smell finally went away.
    When I restored the Caddy (flood total) it smelled like swamp. The carpet must've weighed 150 lbs. because it was soaked with muddy water. Then I washed the carpet itself and the foam backing with a pressure washer (with a low pressure tip) using a carpet detergent that I got from www.topoftheline.com. I let it dry completely and then sprayed it with Microban to kill any mold or mildew that might try to form.
    The car smells fine inside. It has a lingering stale smoke smell from the previous owner, but nothing swampy at all.
    Jim
  8. #7
    Frost's Avatar
    Frost is offline Cadillac Owners Connoisseur
    Automobile(s): 1988 SDV; 1997 SDV D'Elegance
    Aug 2003
    Ontario Canada
    1,401
    Go to you your local veterinarian's shop or a Pet Store and look for a spray or brush detergent that is designed to ELIMINATE dog and cat odours/urine/fecal smells - these smells are "bio" in nature and the sprays you can now get contain ENZYMES that will "EAT" the offending odour.
    Originally designed as a means of discouraging repeat offenders (like FIDO and MITTENS) from returning to the place they marked their spot, this also works well for car interiors,both carpet and upholstered seats.
  9. #8
    turbojimmy's Avatar
    Apr 2004
    New Jersey
    3,963
    Quote Originally Posted by Frost
    The most popular is called "Nature's Miracle" and it's made for 'accidents' including urine, feces and vomit. I'm not sure if the smell the original poster is referring to is due to an 'accident'.
    I also have some stuff called ChemSpec that is an enzyme cleaner designed for commercial carpet extractors. The pros use it to clean restaruant and other high-traffic carpets. I got it on the web somewhere. I haven't used it in the car, but it works awesome in the house on anything organic (for both stains and to eliminate bad smells). It's a powder that you dilute with water. I put it in a little Hoover steam cleaner.
    Jim
  10. #9
    Elvis's Avatar
    Elvis is offline Cadillac Owners Master
    Automobile(s): '05 Expedition
    Jan 2003
    52
    7,651
    Quote Originally Posted by turbojimmy
    That IS good stuff. I've had to use several gallons of it before. It's a pleasant odor that eventually goes away.
    Whatever you have in there stinking things up is ORGANIC. You need to attack it in an ORGANIC way. Enzymatic action is the ONLY way to go. You can buy "Nature's Miracle" and other stuff like it at a PETCO or any other national chain pet store.
    You might need to make two or three applications of it, but I highly recommend it.
  11. #10
    rollman's Avatar
    rollman is offline Cadillac Owners Fanatic
    Automobile(s): STS
    May 2004
    Phila Pa
    174
    What did the detailer do to it ? and where are you located ?
  12. #11
    Kev's Avatar
    Aug 2004
    57
    10,427
    Hey guys, remember science class? Where do odors come from? In most cases it is either moisture or gaseous particles emanating from their source. (Yeah, I know...EEWW!!) We inhale these particles and taste them..... Mmmmm, YUMMY!!
    Thus it is important and often very effective to;
    1. Remove the source of the smell.
    and
    2. Allow any contaminated articles to dry completely or, in the case of gasoline or other evaporative substances, to allow total evaporation.
    These simple steps should eliminate 80 to 90% of the odors, the remainder will eventually wear off and can easily be masked with the freshener of your choice.
  • You may not post replies
