| Re: 05 CTS: 20s or 22s??? Hello friend... Here is the problem.........................................
YES you can fit 22's on a 05 CTS, BUT you will have to get rubber band tiny tires. You must use a 255-30-22 tire. ANYTHING bigger will rub like hell. If you use a 255-30-22 tire, they WILL NOT RUB. The problem is that once you hit a pot hole, your rims will crack. These skinny tires are murderous on rims, especially cheap ebay 22 inch wheels. Dont get me wrong, you may be lucky and not crack them, but chances are that you will crack them if you are not careful because the tires have tiny small sidewalls...
If you get 20 inch wheels, you can use a 245-40-20 tire and you will have plenty of meat on the tires for pothole protection. Also, you can now ever get 245-40-20 inch vogue tires which look bad ass hell on Caddys! They cost about 900 bucks, but you can get some kuhmo or other regular tires for about 100 bucks a tire.
I just went through this whole ordeal. I have a newer Caddy STS and I wanted 22's. I live in Michigan and the potholes here are STUPID AND CRAZY ! ! After LONG debate, I finally decided to go with 20s so I could have a meatier tire. My 20s look great, and everytime I hit a pothole I dont worry as much. I have a sports car with 215-35-18 rubber band skinny tires and I cracked a rim a few months ago. I was pissed.
If pothole protection is not a concern, then get some 22's and get 255-30-22 tires with NO RUBBING...
If pothole are big in your area, then consider 20's with a 245-40-20 or 255-40-20 tire... NO RUBBING |
