Cadillac Detailing and Appearance Modification Interior and Exterior including Body and Wheels Forum for discussions regarding cleaning, detailing, painting, and accessories for enhancing appearance. | Cadillac Forums: Didn't work-it's worse
11-08-08, 06:24 PM
| | Cadillac Owners Connoisseur Cadillac(s): 92 eldorado, 97 S.T.S.. | | Join Date: Nov 2005 Location: roberts creek b.c. canada | | | Didn't work-it's worse I just tried some turtle wax rubbing compound on my 92 eldo, trying to get
rid of minor scratches and scuff marks, I think it looks worse than before, it seems to accent the marks now,anyone else had any expeience with this product?. |
11-08-08, 06:53 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: Didn't work-it's worse  Rubbing compound is for removing orange peel and really nasty stuff before going to lighter and lighter grit polishes. Polishing compound would have been better, but still too aggressive for today's multiple part clearcoat finishes.
Go to www.autogeek.net , make a stiff Scotch and water, and do some reading. |
11-08-08, 07:05 PM
| | Cadillac Owners Connoisseur Cadillac(s): 92 eldorado, 97 S.T.S.. | | Join Date: Nov 2005 Location: roberts creek b.c. canada | | | Re: Didn't work-it's worse Quote:
Originally Posted by submariner409  Rubbing compound is for removing orange peel and really nasty stuff before going to lighter and lighter grit polishes. Polishing compound would have been better, but still too aggressive for today's multiple part clearcoat finishes.
Go to www.autogeek.net , make a stiff Scotch and water, and do some reading. | Thanks,it actually is polishing compound, I am afraid to go at it too aggressively because of the clearcoat,I'll have a look at autogeek. |
11-10-08, 08:52 AM
| | Moderator Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's | | Join Date: Apr 2003 Location: Huntingdon Valley, Pa. | | | Re: Didn't work-it's worse You would only want to use polishing compound to repair a bad scuff, and never rubbing compound on a clear coated car. You probably used the product and it was way to aggressive, you will need to use a less abrasive product, and maybe a few of them depending on what damage was done already. Always best when used with something like a Porter Cable or Flex buffer, if you do not have one, you may want to find a good body shop or good detail shop to buff your problem areas out so then it will be easier to keep it looking good.
__________________ Carl V.
**Authorized Zaino Distributor **
**Authorized Amsoil Dealer** Web Site hcvind.com |
11-10-08, 07:33 PM
Originally Posted by hcvone You would only want to use polishing compound to repair a bad scuff, and never rubbing compound on a clear coated car. You probably used the product and it was way to aggressive, you will need to use a less abrasive product, and maybe a few of them depending on what damage was done already. Always best when used with something like a Porter Cable or Flex buffer, if you do not have one, you may want to find a good body shop or good detail shop to buff your problem areas out so then it will be easier to keep it looking good. | Thanks for the advice,also would you know the address (email) for the Canadian Zaino distibutor,It's been a few years since I ordered any supplies,I think it's in Ontario. |
11-11-08, 08:28 AM
| | Moderator Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's | | Join Date: Apr 2003 Location: Huntingdon Valley, Pa. | | | Re: Didn't work-it's worse Here it is:
Mike Adams
Crown Auto Emporium
325 Eramosa Rd.
Guelph, Ontario N1E 2N1
(519)763-8473 http://www.zaino.ca
Email: mike@zaino.ca |
11-11-08, 02:54 PM
Originally Posted by hcvone | Thank you, btw ,does zaino make a product for light scratches and scuff
marks?. |
11-12-08, 08:57 AM
| | Moderator Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's | | Join Date: Apr 2003 Location: Huntingdon Valley, Pa. | | | Re: Didn't work-it's worse Creeker, there is our Z-AIO, this is an all in one cleaner wax product, it will remove very light scratches with a buffer, or Z-PC is probably what you want, it's more aggressive. http://www.zainostore.com/Merchant2/...roduct_Count=6 |
11-12-08, 01:52 PM
Thank you | | Cadillac Discussion Tools | | |
Censor is ON | | | |
