Yes, you will need to replace all the small light bulbs from the dashboard, doors, map, visors and under dash lights with LED's. BUT IS NOT A PLUG AND PLAY THING. Every single LED needs an appropriate size resistor to limit the current.
- You will have to remove the stereo and climate control module and replace about 15 light bulbs (from each) plus some 3-7 resistors (this require allot of desoldering/soldering). I will post the schematics with which one and what values when I will have some time.
- The PRND123 back light from the shifter is done by two light bulbs witch can be replaced with 4 LED's (plus 2 resistors, don't forget about resistors) mounted on a small piece of PCB that will fit in the outlets (pretty time consuming job).
- The heated seats buttons need to be taken apart to replace the light bulb inside (each button) with one LED and (+ resistor).
- The Info/Trip reset/trunk/Gas door release/Info reset buttons are illuminated by 3 socket-mounted light bulbs. They can be replaced by fitting the LED in the socket and the resistor on the back of the socket.
- Map lights (the lights above the doors) are using 168/194 light bulbs (same as the one for the license plate). They can be founded already made on e-bay or can be made using a small peace of PCB and 6 LED's (+ the resistor). Again this require EXTREME soldering.
- Door lights (the one above the window switches) are using same idea of socket-mounted light bulbs as the Info module (same solution, LED in the socket and resistor in the back).
This is what I got so far. I still need to replace the Instrument Cluster lights (which is pretty much the most important); the headlight switch light, rear climate control light, glove box light and under dash lights.
Maybe somebody can help me with some points how to access the instrument cluster lights (I haven’t got a chance to look in to it, I hope is possible to reach from under the dash without removing the instrument cluster).
One more thing, LED’s are basically diodes so the polarity is important.
Well is a heck of a job, I am working in every weekend since 3 weeks ago and I still need at least two more, but the result IS FANTASTIC. Not to mention that one LED is using about 3-4 time less power (makes the battery happier)
When I’ll be done I will post pictures, and details with what and where.
Until then, here is a picture (after doing the stereo and climate control module). Notice the color difference between stereo/climate control module and the buttons on top of the stereo or the passenger side under dash light.
