Cadillac Detailing and Appearance Modification Interior and Exterior including Body and Wheels Forum for discussions regarding cleaning, detailing, painting, and accessories for enhancing appearance. | Cadillac Forums: cleaning stainless exhaust tips
05-18-07, 02:09 PM
|  | Cadillac Owners Fanatic Cadillac(s): 2006 STS V8 | | Join Date: Aug 2006 Location: Summerland Key, FL Age: 30 | | | cleaning stainless exhaust tips Brasso metal polish will make them look brand new! Available at WalMart in metal container. |
05-19-07, 09:06 AM
| | Cadillac Owners Fanatic | | | | | Re: cleaning stainless exhaust tips Thanks. They look like crap compared to my 99. But another reason to buy Corsa.
I'll check the garage for Brasso!
CG |
06-25-07, 06:22 AM
| | Cadillac Owners Member | | | | | Re: cleaning stainless exhaust tips for CLEANING.. i say just save the $ and use some vinegar.
that's all i've ever used on all the polished-stainless tips i've had, hit em with the hose real quick when done=no smell
for POLISHING.. there's lots of options. |
06-27-07, 05:46 PM
| | Moderator Cadillac(s): 2009,2008,2007 Escalade's, 2008,2006 SRX's | | Join Date: Apr 2003 Location: Huntingdon Valley, Pa. | | | Re: cleaning stainless exhaust tips I use SOS soap pads to get the clean, does a great job.
__________________ Carl V.
**Authorized Zaino Distributor **
**Authorized Amsoil Dealer** Web Site hcvind.com |
07-01-07, 10:45 AM
|  | Cadillac Owners Master Cadillac(s): 1989 STS / 2001 DTS / 2002 DTS | | Join Date: Apr 2005 Location: Upstate NY | | | Re: cleaning stainless exhaust tips I use Simple Green and 0000 steel wool. Then I clean up with Windex. I'm sure many things will work.
I clean my glass with the same things.
__________________ Ownership:
89 STS (1 of 1893) - FOR SALE
02 Blue Onyx DTS 01 DTS: Custom installed Volant CAI Custom PCM Body color engine components Cruiser Alloy wheels EBC brakes Eibach springs
Corsa exhaust Sportwing Spoiler Semi-custom interior Custom quad Hi-Beams Future Plans: More interior work. Memberships: National and regional Cadillac & LaSalle Club Proud Volunteer - Northstar Tuning Project ---------------------------- |
07-04-07, 05:08 PM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: cleaning stainless exhaust tips Some automotive stores sell a cotton wadding polish called NevrDull. Long used for aluminum aircraft skin, it's now everywhere. The cotton smells like it's saturated with paint thinner, but there's more than that. It will clean s/s, and polish darn near any smooth metal, but don't use it on clearcoated metals or wheels because it will remove the protective finish. (Used to use it to polish the brass in the conning tower or periscope stand.......) |
06-26-08, 12:09 AM
|  | Zeeee-yaaaa Cadillac(s): 07 STS 1SG, 03 STS, 74 Eldo, 98 Z28, PAST: 97 ETC | | Join Date: Oct 2005 Location: Cheswick, PA Age: 23 | | | Re: cleaning stainless exhaust tips i just went to clean my corsa's tips and thank GOD i did
the one tip was so loose another back road jaunt id of lost it
im taking it in next week and finally welding the damn system together i didnt at 1st as i wanted it to settle and then adjust the tips perfectly straight then weld it... |
06-26-08, 11:29 AM
|  | If it won't run, chrome it..... Cadillac(s): 2002 Cadillac F55 STS/53000mi., 2004 Ford F150 Super cab 4x4 | | Join Date: Feb 2006 Location: Maryland upper Eastern Shore Age: 69 | | | Re: cleaning stainless exhaust tips Jay, That's strange.......I did my system in 11/06 and used the anti-seize on the threads and torqued according to the install paper, and everything is still tight. Your post worried me, so just took the car off the lift after checking. (Sprayed the mufflers and Y pipe with flat black hi-temp rattlecan. You can't see a thing from behind the car........  ) |
06-26-08, 12:20 PM
| | Cadillac Owners Fanatic Cadillac(s): White Diamond 98 Eldorado | | Join Date: Feb 2004 Age: 60 | | | Re: cleaning stainless exhaust tips Barkeepers Friend, in the gold can anywhere cleaners are sold....2 bucks. It never scratches. | | Cadillac Discussion Tools | | |
Censor is ON | | | |
