How can i checkifmy cts has a recall?
Results 1 to 3 of 3
Cadillac Customer Care Representatives - Warranty or Dealership problems Discussion, How can i checkifmy cts has a recall? in Cadillac Customer Care - Warranty and Dealership questions; 2007 cts recall due to timing chain failure ? And also need to reprogram my engine control module to prevent ...
    Mralex is offline Cadillac Owners Member
    Automobile(s): Cts
    Jul 2013
    29
    And also need to reprogram my engine control module to prevent early timing chain failure ?
    RippyPartsDept's Avatar
    Sep 2007
    Wilmington, NC
    13,986
    Re: How can i checkifmy cts has a recall?
    any dealer (such as myself) can run your VIN and see if there are any open recalls or campaigns
    the timing chain issue that you are talking about (at least what i think you're talking about) is a warranty extension that covers you for an extended period of time past the bumper to bumper warranty for just one particular repair (in this case it's the timing chains)
    there was a recall in relation to the timing chains but that was just a software reprogramming that did a few things to try and keep the timing chain failures from happening
    one of those things was shortening the oil life monitor so people who never check their oil level will not run out of oil and damage their engines between oil changes
    another was to change the value of chain slack monitored by the chain tensioner that would provoke a check engine light
    there were probably other changes but those are the only ones that i know of
    if you email me your VIN i will send you your warranty info and vehicle build sheet in PDF format
    Jaxle67's Avatar
    Jaxle67 is offline Cadillac Owners Member
    Automobile(s): 2004 cts
    Nov 2012
    savannah ga
    95
    Im sure checking with deslership is the best way for recalls but ive had 2 seperate insursance companies that would provide me any recals and tsbs on all my vehicles
    Jesse
    Or just email rippy amd all is dolvrd
    Solved that is still getting used to tablet typing
