Dealer says AWD system, ABS, STeering Assist, and TC shutting on/off due to miss. ??? - Page 2
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Cadillac Customer Care Representatives - Warranty or Dealership problems Discussion, Dealer says AWD system, ABS, STeering Assist, and TC shutting on/off due to miss. ??? in Cadillac Customer Care - Warranty and Dealership questions; Where in the world did you find a shop rate of $80/hr? It's at least a $100/hr anywhere else. Maybe ...
  1. #16
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,316
    Re: Dealer says AWD system, ABS, STeering Assist, and TC shutting on/off due to miss.
    Where in the world did you find a shop rate of $80/hr? It's at least a $100/hr anywhere else. Maybe you should have bought a less expensive car.
    Don't mess with Binky Bear!
  2. #17
    mhamilton is offline Cadillac Owners Connoisseur
    Automobile(s): 2006 XJ, 2000 Eldorado ESC--total loss :(
    Aug 2009
    North Carolina
    1,180
    GM has told me because the dealer can't pull the code my local Advance Autoparts can and because they think that a non-existent ghost engine miss (the car gives out no miss codes, only loss of communication with the ABS system) they will not help me. Great.... Last GM for me....
    Um, if the 1st dealer said there's a code for "loss of communication with the ABS system" why don't they diagnose and fix that issue first? Clearly an ABS system fault can cause a loss of traction control. If the ABS system is not functioning due to a fault there's little the car can do to control traction or stability.
    I can understand your frustration with a poor dealer experience, have been there and done that. But don't go off the deep end about the car because of one incompetent dealership service department. If there's a fault with the ABS, then it can be diagnosed and repaired, and will likely solve all the traction/4wd issues. It's not a Cadillac thing, most cars will disable stability and traction when a single system fault exists (e.g. Mercedes, Chrysler, probably all modern cars).
  3. #18
    DaPurpleRT's Avatar
    DaPurpleRT is offline Cadillac Owners Fanatic
    Automobile(s): 2015 Cadillac ATS Premium 3.6 AWD Coupe
    Sep 2011
    33
    214
    Actually the first dealer told me it was putting out a misfire code (though no one else could pull this code) and that was causing this issue. I took it to Advance Autoparts directly after and they pulled the losss off communication code the dealer couldn't.
    Back when the car did have a miss (ended up being plugs/a coil pack), both this dealer and the next closest said they couldn't feel the obvious miss... and it progressed and progressed so I just took a shot and replaced those items at 80k miles. Had several other what the heck moments too, but Cadillac customer support always told me it is their policy to stand behind the dealership, hence my disillusionment.
  5. #19
    CTSCHICK Guest
    Just a thought since I am not multi tasking I had occasional random T/C shutting off in my G5GT that was tied to a misfire.
    That is part of the programming in the PCM
    Anyways after Gm replacing my coils, plugs and fuel injectors twice the problem was still present randomly after each repair because my b.f. would scan my car and do live data with the car running and while I drove it viewing the misfire count table.
    The misfires were just below the amount of misfires needed most of the time to where the Pcm would enable the DTC and service engine light.
    It got to a point where my b.f. installed my own permanent mount scan gauge in my car with a pillar pod so that I could data log my misfires while driving to prove that they still existed.
    So my b.f. used his scope to inspect the inside of my engine and determined it was a valve problem, which I had fight with 2 dealers to get fixed and then Pontiac customer service sent me to 3rd dealer who listened to my b.f.'s diagnoses and they consulted with a Gm engineer to come to same conclusion.
    And that fixed my problem, the occasional DTC's and T/C off all ended with the replacement of the cylinder head.
    The dealer Tech can view the misfire counts separately while the engine is running and or driving with a load on it with the GM Tech2 Diagnostic scanner tool that they use..
    Just a thought in case your Loss of communication with the ABS doesn't come back after it has been cleared.
    With all of the problems I have read that you have had a diagnostic scanner that also does ABS,Air bags and live data would pay for its self after a problem or 2 instead of paying the diagnostic fee's at the dealer IMO
  6. #20
    dkozloski's Avatar
    Jul 2004
    Fairbanks, Ak
    28,316
  7. #21
    DaPurpleRT's Avatar
    Sep 2011
    33
    214
    Thanks for the thought, but unfortunately, that would be covered under the powertrain warranty, and the dealers will not look at anything covered under that until they exhaust every conceivable non-covered option. So, hoping it is not this....
  8. #22
    SlvrDude is offline Cadillac Owners Member
    Automobile(s): Escalade
    Dec 2012
    3
    Quote Originally Posted by DaPurpleRT
    Slvrdude.
    Regarding your ABS issue have same prob on my '04 Escalade traction control light comes car stalls out no AWD. Problem diagnosed as bad ABS sensors in FWD hubs. R&R problem solved... Common to all industry vehicles with AWD my dealer has had quite a few show up in his repair bay of late. Hope this helps.
  9. Remove Advertisements
