| Re: Entry/Exit settings in DIC If you had expressed this complaint to your dealer, he would tell you that everything is operating normally and your complaint was not the first he had received. I, too, have this problem, and there is, as far as I know, no resolution. Rather than wait until the permanent "key" is turned and then adjusting the seat and steering wheel, as my 2004 and 2005 CTS-Vs sometimes did, it is done when you open the door. Stupid, huh? This is not what the owner's manual says will happen, but this is not the only thing that is incorrect in that book.
My solution to this problem is to set the programming for no changes when the driver door is opened. I then use the button on the door to set the driving position. When I exit, I use the exit button. Since the programmming is set for no change when the driver door is opened, it remains in the exit position until I get in and push the button, ususally number 1, to set the driving position. My wife's 2008 DTS works exactly the same way. I complained then and over a year later nothing had changed.
