Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2009+
Cadillac CTS-V Series Forum - 2009+ Forum specifically for discussions regarding the fastest v8 production sedan in the world - the 2009 Cadillac CTS-V with 556 horsepower.
2009-cadillac-cts-v-series
Cadillac Forums: Synthetic oil life?
Old 09-30-09, 10:20 PM
Cadillac(s): 04 CTS-V, 09 CTS-V
View Qnsryck's Photo Album
Casino Cash: $1745
Synthetic oil life?
I changed my fluids to Amsoil about 3K miles ago and now I'm getting the message that I need to change my engine oil. I don't know what triggers the dash message but I was thinking the Amsoil lasted much longer than the usual 3K change. Do I really need to change it?
  #2 (permalink)
Old 09-30-09, 10:45 PM
Cadillac(s): 2005 STS V8
View Caroutisine's Photo Album
Casino Cash: $15767
Re: Synthetic oil life?
Did you reset the oil life monitor when you changed the oil?
  #3 (permalink)
Old 09-30-09, 10:46 PM
Cadillac(s): 2009 CTS-V
View SlvrBullIT's Photo Album
Casino Cash: $3745
You didn't reset the oil life monitor in the DIC. At the oil life setting holding down the reset button resets to 100%.
  #4 (permalink)
Old 10-01-09, 07:03 PM
View Jeffrey's Photo Album
Casino Cash: $635
Hi,
Is the V only accurate on Mobil 1 life or will it accurately measure the life of all major brands?
Best regards,
Jeffrey
  #5 (permalink)
Old 10-01-09, 07:40 PM
Cadillac(s): NONE
View Looney100's Photo Album
Casino Cash: $1185
I suspect the engine oil life indicator is much less sophisticated than many may think. My guess is it just takes note of how much idling you do, engine temps, mileage, throttle position, etc. and guesses how much life is left with no regard to the type of oil you're using.
The system doesn't have any built-in engine oil analysis probes, etc. so it really has no idea how the viscosity, etc. is - just making an educated guess based on your driving habits
  #6 (permalink)
Old 10-01-09, 08:42 PM
Cadillac Owners Enthusiast
View tedcmiller's Photo Album
Casino Cash: $7692
The engine oil life warning is a program that checks the engine RPM and the engine temperature and computes the remaining oil life based primarily on these two parameters. It assumes a good grade of oil but does not distinguish between synthetic or petroleum based oils. Typical mileage between 100% and 0% oil life is 7 to 8 thousand miles. On earlier models, a warning would be displayed when the oil life reached 10% and then a warning would be displayed when the oil life went to 0%. Now only the 0% warning is displayed. Most people assume the program that computes remaining oil life is more sophisticated than it actually is.
  #7 (permalink)
Old 10-01-09, 09:23 PM
Casino Cash: $1745
Thanks for all the help. I did not reset the notification. I guess I figured a system that is so smart to figure lubrication efficacy would know it had a clean and pristine lubricant in it. I guess that corroborates with the posts that suggest the "oil life" system ain't as smart as we think it is.
I still like the system because it's way better than the sticker in the windshield.
So, how do I know when the Amsoil should be changed? Does it darken as does conventional oil? Is there a litmus test for the dipstick?
Terry
  #8 (permalink)
Old 10-01-09, 10:26 PM
Casino Cash: $15767
I would just reset it now, then change oil again when it indicates about 30% oil life left.
  #9 (permalink)
Old 10-02-09, 01:28 AM
CTS-V-TWIN's Avatar
Cadillac(s): 2009 CTS-V, 2009 Escalade
View CTS-V-TWIN's Photo Album
Casino Cash: $12370
Terry
Terry,
If you are running Amsoil with an Amsoil EA oil filter, you can run it for 25,000 miles or one year, whichever comes first.
I am running Amsoil 0w30 Signature Series Synthetic Oil and the EA oil filter and I will just change it at the one year mark since I don't drive 25,000 miles per year.
As long as you know how many miles you had on the car and the date when you changed it over to Amsoil, you can keep a track of it that way.
SG
DR. V-TWIN, INC.
4852 VAN NUYS BLVD.
SHERMAN OAKS, CA 91403
888-DR-V-TWIN TOLL FREE
818-501-TWIN (8946) LOCAL
818-981-TWIN (8946) FAX
WWW.DRVTWIN.COM
INFO@DRVTWIN.COM
  #10 (permalink)
Old 10-02-09, 09:01 AM
Z71's Avatar
Z71 Z71 is offline
Cadillac(s): 2009 CTS4 Blue Diamond
View Z71's Photo Album
Casino Cash: $4730
The oil life monitor is just a computer algorithm that uses engine revolutions, engine heat cycles etc to run a countdown clock. It does not sample the oil and must be reset by the used when the oil is changed.
I have used AMSOIL for over 30 yrs. I have SSO 0W-30 in my 2009 CTS. I drive less than 10,000 miles a year so I will change oil in one year. If the OLM telling me to change oil sooner I just reset it. If often change the filter midway thru because its so easy to do and they filters are not that expensive providing you don't buy it from the dealer. I use AC Delco or a WIx.
AMSOIL has any oil filter for the CTS-V, the EaO-50. No air filters though. The V76 engine has not AMSOIL oil filter available for it.
UP to 25,000 miles or 1 yr
Yes, but darkened oil is not a bad thing. It just means to oil is doing it just job.
You can take white business card, put a drop of on the card and wait for it to soak into the card. Might have to leave it sit for a few hours. The observe the spot. If the spot in consistent color and had not dark ring then the oil is free of carbon and the filter is doing its job.
  #11 (permalink)
Old 10-02-09, 02:05 PM
Casino Cash: $7692
It should be noted that the OnStar diagnostic reading that is normally done once a month and sent to your e-mail (if you have OnStar and have signed up for it) begins to flag the oil as needing changing after one year even if the oil life monitor has not gone to 0%.
  #12 (permalink)
Old 10-03-09, 01:40 AM
Cadillac(s): NONE
Casino Cash: $1185
Guys, never extend your drain intervals that significantly without having the used oil tested along the way. It doesn't matter how great your oil is, if you get accumulation of contaminants, its going to fail on you.
  #13 (permalink)
Old 10-03-09, 02:00 AM
Vrocks's Avatar
Cadillac(s): CTS-V
View Vrocks's Photo Album
Casino Cash: $4575
I'm also switching to amsoil - it arrived today with the EAO-50 filter. Even though it should be safe for atleast 10,000 miles, I'm going to change it every 5-7,000. It's not overly expensive and the filter was <$15.
As far as oils go, I may try Mobil's 0W-30/40 racing oil next time (it has a higher visc rating)... similiar formula to amsoil. The main reason for why they say not to use it in a street car is due to pollution control - 2x as much Zinc and something else for extra lube / protection. I just don't know if it's engineered to last for 5,000+ miles...
  #14 (permalink)
Old 10-03-09, 12:05 PM
CTS-V-TWIN's Avatar
Casino Cash: $12370
Stick with the Amsoil. It has more proven protection over any other oil on the market and is guaranteed to provide protection for 25,000 miles or 1 year. Why waste money? Amsoil is great because I will only have to change it once a year which will save me some cash and provide some environmental benefits of not having to recycle the used motor oil and not having to recycle the oil filter frequently.
I did my first oil change back on March 11 of this year when the car had 1,908 miles on it and I have driven 6,000 miles since. I will change the oil at the 1 year mark as I know I will not have driven anywhere near 25,000 miles by that time.
SG
  #15 (permalink)
Old 10-04-09, 11:41 AM
Cadillac(s): 09 CTS-V Red/Ebony Recaros w/MF, pol whls, roof, Nav, 6MT
View marktanner's Photo Album
Casino Cash: $6645
Porsche uses Mobil 1 0-40 in their cars, including the GT3. Their recommended oil change interval is TWO years or 30,000 miles, regardless of usage (including track work; I asked at the factory). It's not the quality of the oil that's driving the recommendations, unless Porsche feels that the base stock in the 0-40 is different and superior to the other grades. Porsche does not include maintenance in the warranty, so it has nothing to gain by skimping on oil changes.
Interestingly, the regular CTS DI computer seems to be set for twice the oil life as the V, usually a minimum of 10,000 miles, or more. They still recommend no more than a year for the Mobil 1, though. Does any one know the recommendations for the base Corvette, which is basically the same engine as the LSA without the supercharger?
Tags:
life, oil, synthetic
