Go Back   Cadillac Owners Group > Current Cadillac Vehicle Discussion > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2009+
Cadillac CTS-V Series Forum - 2009+ Forum specifically for discussions regarding the fastest v8 production sedan in the world - the 2009 Cadillac CTS-V with 556 horsepower.
2009-cadillac-cts-v-series
Cadillac Forums: Jacking the CTS-V
Old 07-17-09, 10:44 AM
Low_ET's Avatar
Cadillac(s): '09 CTS-V, Thunder Gray, Auto
View Low_ET's Photo Album
Casino Cash: $3590
Jacking the CTS-V
Has anyone found a floor jack that works on the CTS-V?
The regular CTS jacking points are covered by trim so we can't use the pinch weld jacking points shown in the owner's manual.
The shop manual (page 1-26) shows lifting by the torque boxes (front and rear). My floor jacks (I have three different ones) won't reach the torque boxes while clearing the lower trim.
By the way, I have RaceRamps. They work great, just not to get to the tires, brakes, etc.
  #2 (permalink)
Old 07-17-09, 11:01 AM
Cadillac(s): 2009 CTS-V
View 62Jeff's Photo Album
Casino Cash: $7040
Re: Jacking the CTS-V
This is an admittedly uninformed response - but I wonder if the jacking pucks for my 07 vette would work on the CTS-V?
The vette has openings behind the rockers, to which pucks are installed. These pucks allow a floor jack to reach a solid jack-point before other parts of the jack hit the sills.
So it has me wondering if the CTS-V has the same openings as the vette.
  #3 (permalink)
Old 07-17-09, 12:44 PM
Low_ET's Avatar
Casino Cash: $3590
I am not familiar with the Corvette jacking points so I don't know if that would work. What do the pucks look like and how do they mate with the Corvette lift points?
A picture is worth a thousand words.
  #4 (permalink)
Old 07-17-09, 02:49 PM
Cadillac(s): Ordered CTS V - ordered 03/13 delivered 06/24!
View Hawkeye2's Photo Album
Casino Cash: $4910
I have a Z06 and I bought the pucks. I'll check the V this weekend to see if they might work. I have Raceramps as well, and since I
plan on checking my half shafts this weekend - the V is going up. I'll use the Ramps, and then look for a spot to use my floor jack once the
car is in the air, then put on stands - if I have to. My thought.
  #5 (permalink)
Old 07-17-09, 03:50 PM
Cadillac(s): CTS-V 2009 White Diamond, 996TT Silver
View jwa999's Photo Album
Casino Cash: $6155
I found the stands AZstar was using in his caliper Painting post interesting:
Originally Posted by AZstar View Post
  #6 (permalink)
Old 07-17-09, 04:27 PM
rp161's Avatar
Cadillac(s): 2009 cts-v
View rp161's Photo Album
Casino Cash: $970
I bought the Harbor Freight racing floor jack. Works great and fits in the space where the spare tire
should have gone.
  #7 (permalink)
Old 07-17-09, 07:18 PM
Low_ET's Avatar
Casino Cash: $3590
The stands AZstar is using look like they are right under the jacking points. My stands look like those.
About the Racing Jack: Would it have enough clearance if the car was 1-1/2" lower (like you had a flat tire)?
  #8 (permalink)
Old 07-17-09, 09:13 PM
Casino Cash: $7040
This is a picture of one of several brands of pucks. They just slip up into a slotted hole, and then you twist.
Some vette owners buy hockey pucks and add a big Eye bolt (really, it's that simple).
  #9 (permalink)
Old 07-17-09, 11:37 PM
RapidRob's Avatar
Cadillac(s): 2009 CTS-V Black/Black, manual
View RapidRob's Photo Album
Casino Cash: $7385
I was thinking about picking up a set of the Raceramps - did you have to buy the extenders, or is the angle clearance sufficient without them?
Thanks.
Rob
  #10 (permalink)
Old 07-18-09, 10:22 AM
Low_ET's Avatar
Casino Cash: $3590
The standard RaceRamps work great. Extenders are not needed. I bought the 56" two-piece ramps for better access behind the wheels (~$225).
Re: Pucks - There is not a slotted hole for the pucks on the CTS-V. A puck might work but we will have to think up another way to attach them (magnets?).
  #11 (permalink)
Old 07-18-09, 03:16 PM
Cadillac(s): 2009 CTS V
View Prof's Photo Album
Casino Cash: $275
I use an alum. low profile floor jack from Sears...as you noted the rear is pretty obvious...I went straight to the frame rails as shown in the picture above with the jack stands...worked fine...
To clean the CTS V wheels and calipers the wheels have to be removed IMO.
  #12 (permalink)
Old 07-18-09, 11:56 PM
View KatMcRat's Photo Album
Casino Cash: $1010
I'm pretty sure the pucks will fit. We took a pic today when Pat changed the oil in my car today. I didn't have the pucks at home or I would have tried.
  #13 (permalink)
Old 07-19-09, 11:58 AM
Casino Cash: $4910
Good info. Ditto the raceramps, the 2 piece is just perfect. It almost hits the lower air dam, but it does not. They are easy to use and store.
I got lazy yesterday and did not try my pucks. Today is a honey do day, so we'll see.
  #14 (permalink)
Old 07-19-09, 10:03 PM
Casino Cash: $1010
Pat confirmed the pucks fit and it's even double reinforced area.
  #15 (permalink)
Old 08-06-09, 01:46 PM
Low_ET's Avatar
Casino Cash: $3590
I found that BMW makes a jacking puck that you can install permanently (unlike the Corvette pucks that you have to remove). BMW makes them in two styles - round and rectangular. The round ones fit in the rear slotted holes.
BMW Pad: http://cgi.ebay.com/ebaymotors/Lift-...ht_1675wt_1167
My CTS-V does not have slotted hole in the front so I can't use either the Corvette pucks or the BMW pucks. I found Mercedes pucks that can be adapted to fit the round holes in the front jacking locations.
Mercedes Pucks: http://cgi.ebay.com/ebaymotors/Jack-...ht_3087wt_1167
Photos: Puck and Homemade washer to adapt to CTS-V.......... Mercedes puck Installed
File Type: jpg Mercedes jack pad installed (front).jpg (105.9 KB, 16 views)
Tags: , ,
ctsv, jacking
