Cadillac CTS-V Series Forum - 2009+ Forum specifically for discussions regarding the fastest v8 production sedan in the world - the 2009 Cadillac CTS-V with 556 horsepower.
 | Cadillac Forums: D3 CTS-V Baseline and First Tune
02-01-09, 08:25 PM
|  | '09 V For Sale. Ask. Cadillac(s): 2009 CTS-V (for sale) | | Join Date: Nov 2008 Location: Northern VA | | | Re: D3 CTS-V Baseline and First Tune Quote:
Originally Posted by Razorecko The gearing might be better on the auto but the gearing has nothing to do with hp/tq numbers. | The gearing will most certainly have something to do with measured rear-wheel HP numbers (more specifically: torque numbers). It's why manual transmission dyno runs are usually done in 4th gear, which is almost always a 1:1 ratio. In the case of the V's auto, it's a 1.15:1 ratio.
jas |
02-01-09, 08:39 PM
| | Cadillac Owners Connoisseur Cadillac(s): Cadillac | | | | | Re: D3 CTS-V Baseline and First Tune Quote:
Originally Posted by jvp The gearing will most certainly have something to do with measured rear-wheel HP numbers (more specifically: torque numbers). It's why manual transmission dyno runs are usually done in 4th gear, which is almost always a 1:1 ratio. In the case of the V's auto, it's a 1.15:1 ratio.
jas | ^ gotcha. I'd still like to know the mileage #'s as more than one member has mentioned the car really opening up after a few hundred miles. |
02-01-09, 11:24 PM
| | Tuning, Racing, Makin parts for Caddys. Cadillac(s): 2009 v, 2005 v, SRX, STS v, GTM supercar with Cad parts. | | Join Date: Jan 2009 Location: warsaw indiana | | | Re: D3 CTS-V Baseline and First Tune Razorecko what state are you in? |
02-02-09, 10:52 AM
Originally Posted by wait4me Razorecko what state are you in? | Illinois, nw suburb of chicago - why ? |
02-02-09, 11:18 AM
| | Tuning, Racing, Makin parts for Caddys. Cadillac(s): 2009 v, 2005 v, SRX, STS v, GTM supercar with Cad parts. | | Join Date: Jan 2009 Location: warsaw indiana | | | Re: D3 CTS-V Baseline and First Tune I was just curious. Im only 2 hours from you. If you ever got bored, your more than welcome to come check out things here and i can show you around on the software side of this car. |
02-02-09, 01:29 PM
|  | AKA ~ Craig Cadillac(s): NONE | | Join Date: Mar 2007 Location: Southern California | | | Re: D3 CTS-V Baseline and First Tune Quote:
Originally Posted by Varsity Q. Why aren't you changing the pulleys as well as dumping more fuel?
Q. Do you remap the gearbox to hold longer to use the power/torque?
Q. Have you added a better flowing exhaust to the map?
Last Q. Who makes the ECU unit?
Cheers | A1: We will be changing more parts on the new V, including adding boost.
A2: We are currently looking into what modifications will be necessary to handle any given amount of added power. We want our parts to not only produce more power, but produce more RELIABLE power.
A3: In this current configuration we ONLY added the ECU box with revised tune. NO other modifications were made.
A4: We make the ECU box. It is a plug n play box similar to the ones we sell/produce for the STS-V and XLR-V.
Thank you. |
02-02-09, 05:07 PM
|  | Cadillac Owners Master Cadillac(s): '05 CTS-V | | Join Date: Jul 2004 Location: Elkridge, MD Age: 37 | | | Re: D3 CTS-V Baseline and First Tune ECU box = MAF translator?
-Chris
__________________ 2005 CTS-V:No Roof|FG2|Corsa|UUC Shifter, B-Lines, Motor/Tran Mounts, Diff Bushings|LPE CAI|FFV IntakeTube|Hawk HP+ |Hotchkis Sways|Kooks 1.75 Coated LTs + cats|KARS III |Mamofied Fast90 + NW90|224/228 111+0 XFI/XE-R .609/.588|ATI 25% UD Pulley|YT 1.7" UltraLites|Melling HiFlow Oil Pump|Comp Chromeoly 7.425" PR's|Cloyes Hex Adjust Timing Set|Lucas 42# Flow Matched Injectors|Patriot Gold Xtreme Springs, Ti retainers, Super 7 locks|All ARP Fasteners|Mustang Dyno Tuned (SAE): 412rwhp / 380 rwtq |
02-02-09, 05:23 PM
Originally Posted by trukk ECU box = MAF translator?
-Chris | I suppose that's one way to describe it. It's a plug n play box that connects in line with the MAF and loads its tune in there. It is only active when plugged in and once removed, the vehicle returns to factory settings making it a little more user friendly and dealership friendly. |
02-02-09, 09:31 PM
|  | Cadillac Owners Connoisseur Cadillac(s): 05' CTS-V | | Join Date: Feb 2006 Location: Palm Beach Gardens, FL Age: 24 | | | Re: D3 CTS-V Baseline and First Tune 600$ for a MAFT!!!! wow.....I thought the 150$ I spent on my camaro was alot. |
02-03-09, 04:23 AM
| | Cadillac Owners Connoisseur Cadillac(s): 2005 Stealth Gray CTS-V, 2009 Black CTS-V | | Join Date: Jun 2005 Location: CA | | | Re: D3 CTS-V Baseline and First Tune Quote:
jas | I don't think this is correct.
They can do a dyno run in first gear, as long as the dyno was adjusted for it.
This is what I was told though---I make no claims to its accuracy.  |
02-03-09, 11:03 AM
| | BLING IS AMERICAN RICE Cadillac(s): '04 CTS-V | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: D3 CTS-V Baseline and First Tune head esplode
__________________ The Caddy that zigs?
So they were a generation late... Will getting rid of poast counts change how I poast? Dream on...
Currently in the rare 20,000 poast club. 23,327 and counting... |
02-06-09, 12:31 AM
| | Cadillac Owners Member Cadillac(s): NONE | | Join Date: Dec 2008 Age: 46 | | | Re: D3 CTS-V Baseline and First Tune Quote:
Originally Posted by rw99 If Mustang (Eddy Current) dynos load the car more (resulting in lower rwhp/rwtq numbers), and Dynojets don't load as much, where do DynaPacks fit in? It makes sense to me to tune the car on the chassis dyno that most closely mimics real-world loading. | Any info on this? |
02-06-09, 03:18 AM
| | BLING IS AMERICAN RICE Cadillac(s): '04 CTS-V | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: D3 CTS-V Baseline and First Tune this p00p needs to stop. commence. |
02-08-09, 01:14 AM
| | Cadillac Owners Fanatic Cadillac(s): Cadillac | | | | | Re: D3 CTS-V Baseline and First Tune Quote:
Originally Posted by wait4me I was just curious. Im only 2 hours from you. If you ever got bored, your more than welcome to come check out things here and i can show you around on the software side of this car. | Is that invitation open to anyone?
Do you have your own dyno Jesse? |
02-08-09, 01:30 AM
| | BLING IS AMERICAN RICE Cadillac(s): '04 CTS-V | | Join Date: Jun 2004 Location: Just North of Titletown... | | | Re: D3 CTS-V Baseline and First Tune meddling.  | | Cadillac Discussion Tools | | |
Censor is ON | | | |
