http://news.windingroad.com/automoti...adillac-cts-v/
Old news stands true for today?
Cadillac’s CTS sedan is set to debut later this summer
The 2009 CTS-V will use the “LSA” motor. This is another new supercharged, small block V8. This new blown V8 will be good for at least 500hp.
A number of 515-525hp may even be possible, and even higher numbers have been rumored. The CTS-V will feature a supercharger integrated into the intake manifold. This is the same setup the upcoming Corvette SS / Blue Devil will have with its LS9 motor. In the past, the current CTS-V has suffered from rear-end problems. Specifically, wheel hop. The 2009 CTS-V will feature a completely re-done rear end with a much better rear axle. Sources say this has eliminated the wheel hop issue altogether. The ‘09 will continue to utilize a massive set of brembo brakes up front and in back.
If this car is as good as it sounds, dreams can come true.
:bigD:
