Originally Posted by jerrad Dyno tune is far superior. On a canned tune you get a tune that is a little richer and has less timing because the tuner doesn't know your car. A dyno tune will be near perfect if done by the right person. You'll run a good AF ratio and you'll run the most timing you can without hurting the motor. There's probably an easy 15hp difference between a good canned tune and a good dyno tune. |
On a car with only a few mods like exhaust & intake, there's not much sense in paying the extra $$$ for a dyno tune. Costs twice as much, takes longer, can't be done through mail exchange, and might gain you a few extra hp.
On heads/cam/blower cars, yes a dyno tune is pretty much essential to avoid leaving hp on the table and making the car work well with all the mods across the rpm range.
