Go Back   Cadillac Owners Group > Cadillac V-Series Forums > Cadillac CTS-V Series Forum - 2004 to 2007
Cadillac CTS-V Series Forum - 2004 to 2007 Forum specifically for Cadillac CTS-V series discussions.
400 horsepower, TREMEC 6-Speed Transmission and Brembo brakes...
cadillac-cts-v-series
Cadillac Forums: What shifter is better, B&M, Katech, or UUC
  #91 (permalink)
Old 05-12-08, 03:27 PM
lollygagger8's Avatar
lollygagger8 lollygagger8 is offline
CTS-V Owner Lunatic
Cadillac(s): CTS-V
View lollygagger8's Photo Album
Casino Cash: $2055
Re: What shifter is better, B&M, Katech, or UUC
I just installed the UUC shifter and bushings this saturday......I FREAKIN LOVE IT. I didn't hear enough about the Katech or B&M to justify it. UUC shifter is the bomb, and it's really quiet.
You won't have to drop the driveshaft or exhaust, but you will have to get underneath the car and tighten up the bolts that you use (after you drill out the rivets holding the old shifter plate in) and to unscrew the allen head bolt holding the shifter into the carriage. Pretty easy install really.
  #92 (permalink)
Old 05-12-08, 03:45 PM
BacDoc BacDoc is offline
Cadillac(s): Cadillac
View BacDoc's Photo Album
Casino Cash: $2450
Any special tools needed...or odd balls?
  #93 (permalink)
Old 05-12-08, 04:12 PM
CTS-V Owner Lunatic
Cadillac(s): CTS-V
Casino Cash: $2055
I think 10mm were most of the bolts on the inside of the car. If you get the UUC, they come with 1/2" bolts. The screw that holds the shifter in is a allenhead wrech (DUMB) I know it was standard, I think it was a 7/16...I'll try to look at it when I get home. You'll need to chamfer the bushings. I just used scissors and cut at an angle....Lindsey Cadillac ships the shifter with a little bottle of lube....that helps. If not, use white lithium grease. You'll need a angled extension or a moveable joint socket wrench to get around the exhaust...mine's 3" so if you have stock exhaust you'll probably be fine. You'll need a friend to hold the screws on top, and you'll need some patience.
  #94 (permalink)
Old 05-12-08, 04:30 PM
Casino Cash: $2450
Thanks. Need to order the bushing.
  #95 (permalink)
Old 05-12-08, 05:18 PM
AirCav AirCav is offline
Cadillac(s): '06 CTS-V, '95 STS
View AirCav's Photo Album
Casino Cash: $3456
Check out this thread http://www.cadillacforums.com/forums...ml#post1283892 (Easy guide to installing UUC shifter from the top)
if you haven't already. Pictures and everything! Piece of cake.
Zoomers, StealthPower Tune, UUC shifter & bushings; Corvette LS2 FRC; chromed stock wheels, powder coat grill, CTS center console; Beltronics RX75 custom remote installation
  #96 (permalink)
Old 05-12-08, 05:25 PM
Casino Cash: $2450
Thanks.
  #97 (permalink)
Old 05-18-08, 04:05 PM
Casino Cash: $2450
B&M keeps dropping down after I installed it. Like I forgot a clip somehwere but I didn't. Help!
I thought the 2 screws that slide into the metal bracket over the bushing would hold the shifter in place? It just drops down and hits the drive shaft. :/
  #98 (permalink)
Old 05-18-08, 04:35 PM
Casino Cash: $2450
Nevermind.....retaining ring camee off.
  #99 (permalink)
Old 05-18-08, 05:43 PM
Casino Cash: $2450
Shifter is in and my world is a better place. Thanks for everyone's help.
  #100 (permalink)
Old 06-21-08, 07:26 PM
Sherlock Sherlock is offline
View Sherlock's Photo Album
Casino Cash: $1790
A couple people have mentioned that the UUC shifter didn't not seem/feel short enough. (B&M is apparently shorter) Since the UUC and Katech shifters are so similar does anyone know if one is shorter than the other. They both mention a 30% reduction in travel.
Being that the Katech shifter is threaded, I wonder if its possible to cut it down to make it a little shorter.
Tags: , , , ,
bandm, katech, shifter, uuc
Cadillac Automotive Concepts
cadillac air suspension parts
bud davis cadillac
cadillac unlock navigation
earn
vacation travel
golf store
silver, gold, diamonds
hyundai genesis forum | cadillac performance mufflers | cadillac performance exhaust systems | racing seats | cadillac euro tail lights | cadillac air intakes | cadillac projector headlights | cadillac ground effects | cadillac floor mats | cadillac escalade body kits, hoods and lambo doors | cadillac body kits | cadillac carbon fiber hoods
