Custom World Challenge Series Slotting for the Brembo 2 Piece CTSV Custom Rotor Package.
CAD/CAM 3D Model for the Exclusive World Challenge Series 2 Piece Rotors available for your CTSV and Corvette C6 platform are available by email as the file sizes are too large to post to the Forum. Please PM or email me with your email for additional large high resolution digital photos and any questions that you might have. Pictured below is the exclusive World Challenge Series slotting pattern that I am offering on the 2 piece custom rotor package for the CTSV.
Offered below are a number of CTSV brake options that are available that include Brembo Front Caliper upgrades and 2 piece rotors for both the front and rear of your Cadillac CTSV that utilize your OEM Brembo 4 piston calipers.
The CTSV Brembo 8 Piston Front Caliper Package consists of the following:
Two Brembo 8 piston front monobloc forged billet calipers
Two custom machined 6061-T6 billet aluminum radial brackets and all grade 8 mounting hardware
Road Pads with anti-rattle clips
Brake Fluid
Cost of the above Brembo Caliper package is $3595.00 and are available in Red, Silver, Black and Yellow.
Brembo Custom Two-Piece Front & Rear Rotor Packages:
Front and Rear Brembo heavy duty axially vaned (left&right) 12 bolt flanged two piece rotor discs with custom 6061-T6 billet aluminum mounting hats have velocity channels machined into the hat to direct air to the outboard face of disc, Velocity Channels equalize inboard and outboard temperatures, increase the strength of the flange and reduce mass.
Thermal paint is applied to the rotor disc and serves as a visual gauge. Two paints are applied: Green changes at 430 degrees Centigrade - to show that the disc is absorbing heat. Red changes at 610 degrees - telling engineers that the system requires more cooling, or telling a driver to back off to let the brakes cool.
Included in the standard front and rear Brembo two piece rotors are rotor stress relieving, mill balancing and zinc washed. Stainless steel rotor hat mounting hardware. Rotor machining choices that include: smooth finish, gas-slotted or cross drilled.
CTSV Front Two-Piece Rotor Package: $1495.00
CTSV Rear Two-Piece Rotor Package: $1595.00
Custom Rotor Options available:
Rotor Face Machining which includes: The Custom World Challenge Series Slotting Pattern - pictured below
Deep Cryogenic treatment -320 degree and 500 degree heat tempering of the Brembo rotor blanks prior to machining.
Industrial Cadmium Plating versus standard Zinc Washing.
Aerospace Titanium Mounting Hardware versus Stainless Steel.
Rotor disc options are priced on request.
All brake packages are custom built and a 6 week lead time is allowed.
For any additional information on any of the above applications, please feel free to contact me by PM or email at: pietro@comcast.net
Brake Fluid
