CTS vs. ATS
Cadillac Forums | Help Us Help You | Advertise | Cadillac Parts | Cadillac News | Cadillac Classifieds / (Old System)
Results 1 to 11 of 11
Cadillac CTS Third Generation Forum - 2014+ Discussion, CTS vs. ATS in Cadillac CTS Coupe, Sport Sedan and Sport Wagon Forums; Hey! (first post I believe) Without bashing, and without obvious answers (ex: size), what are the differences between these two ...
    skidawgz is offline Cadillac Owners Member
    Automobile(s): Cadillac
    Apr 2007
    1
    CTS vs. ATS
    Without bashing, and without obvious answers (ex: size), what are the differences between these two cars to you? I have been a long time CTS fan, and I'm finally thinking about purchasing a Cadillac. The '13+ ATS and the '14 CTS redesigns seem to be getting fantastic reviews.
    Anyone have any elaborate thoughts on what separate the two cars? Thanks!
    pissedoffwookiee's Avatar
    pissedoffwookiee is offline Cadillac Owners Connoisseur
    Automobile(s): 14 ATS Premium 2.0T Phantom Gray/Morello Red, 13 SRX Carbon
    Mar 2013
    Carlsbad, CA
    1,542
    Re: CTS vs. ATS
    V-Sport is a differentiator
    light blade is avail only on upper two ATS trims, but standard on all CTS
    CTS is about 300 lbs heavier
    ATS has a more airy cabin feel whereas CTS has a more closed in feeling cabin, this is due in part to the dashboard layout...the CTS has a big slab of a dashboard the runs across from the drivers A pillar to the passengers A pillar in one piece with a slight hump over the instrument cluster, ATS has a dashboard the slopes from the windshield downward as it goes into the cabin, with a second binacle piece of dashboard over the instrument cluster, besides the binnacle this is most noticeable by the central AC vents..on ATS they are located to the right and left of CUE on CTS they are directly above CUE, this taller dash feels like theres more car around you like you sit deeper and lower in the car
    CTS has a capless fuel filler
    CTS has an optional reconfigurable instrument cluster
    the mode switch is a rocker in CTS as opposed to a button in ATS, this lets you get to mode you like more directly instead of having to cycle through all of them to go back one
    ATS is better looking from behind than CTS (CTS is a little too conservative here)
    CTS is better looking in the front (both are gorgeous CTS just kicks it up a notch witch makes the rear end even more disappointing)
    the lightblades are more advanced in CTS with the lower half being switchbacks (they turn into amber blinkers when turn signal or hazards are activated and back to DRL when not)
    the CTS key is so much nicer its heavier with a chrome surround, the key blade has a nicer retention system so no accidental disconnects, and trunk release now requires you to press it twice to open the trunk, ATS still uses a 2 second hold for trunk which sometimes gets activated in your pocket
    glove box is electronic
    sunroof has double the glass with skylight over the rear seat on CTS, ATS has traditional small sunroof
    CTS mirrors are smaller, the smallest the government will allow actually, for better areodynamics
    artscadillac is offline Cadillac Owners Member
    Automobile(s): 2007 CTS With Sport Perf Pkg
    Jan 2009
    Delaware
    61
    58
    Re: CTS vs. ATS
    Compare what you get at each level in each car, since a Lux in each is not the same options.
    IE The light blades start at Perf in the ATS.
    ATS must add heated seats as an option, although dealers normally add that on all cars, in cold areas. That should be standard at the Lux level, like in CTS.
  5. #4
    Glamisfan's Avatar
    Glamisfan is offline Cadillac Owners Member
    Automobile(s): 2014 CTS VSport white tri coat/cashmere interior
    Oct 2014
    El Centro, Ca
    41
    Damn good post there Wookie! To me the interiors felt the same. Back seat felt the same. But my wife thought the ATS rear seat felt smaller. I was shooting for the ATS because of the lighter weight. But you can't get ventilated seats on it and that was a deal breaker for me (So Cal desert)! So with the CTS, I went for the VSport so it would more then make up for the weight! And my wife and I love our car! Luxury for normal cruising, and a Mustang, Camaro, 2&3&5 series killer for that occasional stop light race!
  6. #5
    Gavinallan1 is offline Cadillac Owners Member
    Automobile(s): XTS4 Luxury
    Nov 2014
    40
    XTS rocks both the ATS and the CTS.
  7. #6
    evanj21 is offline Cadillac Owners Member
    Automobile(s): 2014 Cadillac CTS 2.0t
    Oct 2013
    82
    Re: CTS vs. ATS
    Doesn't the CTS get more torque with the 2.0 than the 2.0 in the ATS?
  8. #7
    jbonacci is offline Cadillac Owners Fanatic
    Automobile(s): '14 CTS Luxury 2.0T & '13 SRX4 Performance
    Dec 2013
    Rochester, NY
    177
    Quote Originally Posted by evanj21
    Yes, 295 in the CTS, 260 in the ATS. The ATS coupe gets 295 though
  9. #8
    CTSVsport is offline Cadillac Owners Member
    Automobile(s): 2014 CTS Vsport Premium
    Dec 2014
    Houston, TX
    43
    Re: CTS vs. ATS
    I have an ATS 2.0T Luxury as a loaner while my CTS VSport is in for service.
    The ATS feels A LOT smaller. Not cramped, or too small, mind you - just a lot smallER. Also seems a lot lighter. In a lot of ways, the size is more suitable for how I use the car. Definitely has me thinking I should have waited for the ATS-V to come out.
    That said, the fit and finish is at least one notch down from my CTS. Everything seems just "not as nice".
  10. #9
    syndr78 is offline Cadillac Owners Member
    Automobile(s): none
    Mar 2014
    64
    Re: CTS vs. ATS
    Quote Originally Posted by CTSVsport View Post
    Funny, because I feel the exact same way. In fact, I was shopping the ATS 2.0T, when I discovered the Vsport--which I ended up getting. The ATS-V may be the perfect ticket, but the extra 190 HORSES in the CTS-V make me think I may stay with the Bigger car. Even the expected Tune for the ATS won't touch the Stock CTS-V. Not to mention once the aftermarket produces the simple/easy pulley swap and tune, which will likely push the CTS-V over 700HP!!!
  11. #10
    Greg_B is offline Cadillac Owners Member
    Automobile(s): 2014 ATS 2.0T AWD
    Oct 2014
    Dartmouth, Nova Scotia, Canada
    39
    Re: CTS vs. ATS
    I have a 2014 ATS4 2.0T and love it - it really is a very nice car and a hoot to drive. I have sat in a CTS at the dealer and it is a gorgeous car inside. So in that respect I agree with the previous posts. I think the ATS is more akin to a BMW 3-series whereas the CTS is more like a 5-series. The rear seat in the ATS is very tight also. I know the CTS doesn't have the greatest rear seat room but the ATS is even tighter. I am single so that isn't an issue for me and I love the size of my ATS - it is just very flingable and nimble. If I was married and likely to be going out on dinner dates with another couple, or using the car for business clients, I would have needed the CTS for the extra room.
  12. #11
    Jan 2009
    Delaware
    61
    58
    Re: CTS vs. ATS
    For 2015, the ATS Coupe + Sedan both get 295 TQ with the 2.0T.
    The ATS corners better than the CTS, in the various all-season tire configs.
If you do not want to register, fill this field only and the name will be used as user name for your post.
custom floor mats | Cadillac Chrome and Black Chrome Wheels | window tinting
